Ignition connection to Omron fins , Unable to connect,
Citect is able to connect however ignition struggles.
I've tried multiple method even NJ drivers which connects but doesn't get values from tags.
Let me know if you guys can help.
It is difficult to see why your Ignition driver or address configurations aren't working if we can't see them. Please could you include a screenshot of your NJ Addressing configuration and the FINS driver configuration.
If you are having issues with the NJ tags values not updating, you may need to double check how you are addressing your data points:
Omron NJ Driver | Ignition User Manual (inductiveautomation.com)
Also be aware that IA's NJ/NX driver does not browse the tags in the target PLC. You must export from Sysmac Studio and import into IA's device configuration. If you'd like a better experience with NJ/NX PLCs, you probably want to use my alternate EtherNet/IP Client driver:
(Dramatic performance increase, too.)
