Hello,
I have a machine that uses an Omron Sysmac CP1E PLC. I am hoping to connect it to our Ignition server so we can collect data from the machine. After doing some research, I came across the CP1W-CIF41 Ethernet Module, which can be put into the option slot on the PLC and allow for an Ethernet connection on the network. I was able to get it on the network and connect to the web interface.
I am looking for support in how to configure the FINS TCP connection in Ignition. The Omron tech support told me the FINS node address is typically the last octet in the IP, but beyond that didn't have much more information. Does anyone have experience setting up this device connection?
Thanks.
