Buenos días, he iniciado un proyecto recientemente y se me plantea un problema, el cual es el siguiente, necesito crear una única vista emergente y utilizarla para varios motores, es decir, cuando abra la vista emergente el botón que la abra que le asigne los datos del motor correspondiente. Agradecería vuestra ayuda para poder resolverlo. Un saludo. Gracias.
Welcome. Are you using vision or perspective?
Here’s a reference that may help you,
https://docs.inductiveautomation.com/display/DOC80/Popup+Windows
Here is a paraphrased translation for those who can't read Spanish
Good morning, I have recently started a project and I have the following problem. I need a single popup view to be used for several engines.
When I open the popup view, the button that opens it, assigns the corresponding engine data. I would appreciate your help.
All the best. Thank you.
You didn't say vision or perspective, but since you said you want to open a popup view, I will assume perspective. There are a few ways that you can do this, depending on how your project is structured. Specifically are you using UDT type tags or not?
Here is a link to the manual page for popup views.
https://docs.inductiveautomation.com/display/DOC81/Popup+Views
buenos días. Lo siento, no creo que tengan el manual en español. pero los enlaces publicados arriba son la dirección correcta. ¿Está utilizando la visión o la perspectiva? Creará una ventana emergente y utilizará la vinculación indirecta de etiquetas para pasar un número de motor a la ruta. que mostrará el motor correcto.
You can use google translate on the manual.
https://docs-inductiveautomation-com.translate.goog/display/DOC81/Popup+Views?_x_tr_sl=auto&_x_tr_tl=es&_x_tr_hl=en&_x_tr_pto=wapp
