onMessageReceived local variable 'payload' referenced before assignment
I am running version 8.0.15 and on my message handler I am receiving the following message.
def onMessageReceived(self, payload):
	This method will be called when a message with the matching type code
	arrives at this component.
	Arguments:
		self: A reference to this component
		payload: The data object sent along with the message
	self.custom.jobPath = payload
com.inductiveautomation.ignition.common.script.JythonExecException
  File "<function:onMessageReceived>", line 2, in onMessageReceived
UnboundLocalError: local variable 'payload' referenced before assignment
	at org.python.core.Py.UnboundLocalError(Py.java:295)
	at org.python.core.PyFrame.getlocal(PyFrame.java:240)
	at org.python.pycode._pyx689.onMessageReceived$1(<function:onMessageReceived>:2)
	at org.python.pycode._pyx689.call_function(<function:onMessageReceived>)
	at org.python.core.PyTableCode.call(PyTableCode.java:171)
	at org.python.core.PyBaseCode.call(PyBaseCode.java:308)
	at org.python.core.PyFunction.function___call__(PyFunction.java:471)
	at org.python.core.PyFunction.__call__(PyFunction.java:466)
	at org.python.core.PyFunction.__call__(PyFunction.java:461)
	at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:822)
	at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:806)
	at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$TrackingProjectScriptManager.runFunction(ProjectScriptLifecycle.java:687)
	at com.inductiveautomation.ignition.common.script.ScriptManager$ScriptFunctionImpl.invoke(ScriptManager.java:965)
	at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$AutoRecompilingScriptFunction.invoke(ProjectScriptLifecycle.java:752)
	at com.inductiveautomation.perspective.gateway.script.ScriptFunctionHelper.invoke(ScriptFunctionHelper.java:101)
	at com.inductiveautomation.perspective.gateway.model.MessageHandlerCollection$MessageHandlerImpl$1.lambda$invoke$0(MessageHandlerCollection.java:80)
Caused by: org.python.core.PyException
	... 21 more
Ignition v8.0.15 (b2020072213)
Java: Azul Systems, Inc. 11.0.6
I think i solved the issue. It looks like the message handler does not like being sent None for the payload. I changed my code where the message is being sent to send “” if the value is None.
Hmm, so you were specifically calling it as system.perspective.sendMessage("handler", None)? What happens if you just don’t specify a payload argument in the call?
I have a custom property called jobPath that is bound to the this.props.selection[0] of the tree component.
This custom property jobPath then has a change script on it that send the current value as the payload of the message.
def valueChanged(self, previousValue, currentValue, origin):
	This function will be called when the value of the property changes.
	Arguments:
		self: A reference to the component that is invoking this function.
		previousValue: The previous value, as a qualified value object.
		currentValue: The new value, as a qualified value object.
		origin: The origin of the property value. Possible origin values include
		        Browser, Binding, BindingWriteback, Script, Delegate, Session, Project
	jobPath = "" if currentValue.value == None else currentValue.value
	system.perspective.sendMessage(messageType="jobTreeItemSelected", payload=jobPath)
I was not having this issue on 8.0.12
