In past sessions I’ve been able to use the OPC browser without any issues, but now, no matter what I try, I can’t seem to get the OPC Browser to display in Designer. As far as I know, nothing significant has changed, other than my monitor configuration (I’ll explain why I think that may be significant at the end of this post). Ignition version is 8.0.9. The Ignition Tag Browser shows the Ignition OPC UA Server is connected.
Here is what I’ve tried so far:
- Clicking the OPC Browser button on the Tag Browser panel
- Clicking the OPC Browser button on the Vision Main toolbar
- Clicking View > Reset Panels, then View > Panels > OPC Browser
- Restarting Designer
- Restarting Ignition Gateway Service
- Restarting my PC
- Reinstalling Ignition Designer Launcher
- Clearing my Java cache
The panel for the OPC browser just never appears. I’m speculating that the panel is actually running, but positioned outside of my viewable screen space and not resetting with the View > Reset Panels menu option. I think this because when I click the OPC Browser button, the main Ignition Designer window loses focus. Any help would be appreciated.
UPDATE
I unplugged one of my three monitors and I was able to get the OPC Browser to appear that way, so I docked it and plugged my monitor back in. After the next time I reset panels, the same problem from before began to recur and I was unable to get the OPC Browser to appear. I’m still seeking help for a permanent fix for my monitor setup.
I’m having the same problem. Any response from support would be appreciated.
Well, you should probably contact support, then
It should be clarified - the forum is an unofficial support venue. Yes, obviously, there are IA employees here, but if you actually need an answer, you should always go directly to support.
That said, try deleting the windows.layout file in (if Windows) %UserProfile%/.ignition/ and relaunching the designer. That should reset all windows to their default position, which includes having the OPC browser docked.
This fixed the issue. Thank you for your help.
Thanks for the response, but as I stated in my original post, I had already tried to start the OPC Browser panel in the way you are describing. PGriffith’s solution solved the issue for me.
I had the same problem today and found this post from google so I apologize for necroing this thread. My issue came from undocking the OPC server window.
I would Undock the OPC and Tag windows for easy drag and drop of tags. For some reason the OPC window would not open.
My solution was to create another login. For some reason when I logged in under my account it would not fix the designer, but if I logged in as the admin account the OPC window would open in a floating window.
Then all i had to do was dock the OPC window back into the designer and my other login would work correctly. I
It is definately a bug on the ignition side, and I am running a test server in a VMware VM.
It may be late but hopefully this helps the next google searcher.
I was able to view OPC Browser tags by deleting all items from C:\Users\USERNAME.ignition folder and relaunching the project. Deleting only the windows.layout file did not work I had to delete everything in the folder.
