I’m using Ignition 8.0.4, and trying to add a third party OPC Server to the gateway. Under configuration -> OPC Client -> OPC Connections I click create new connection. I select OPC UA, then I type in the end point host and port. I click next, then I see Internal Server Error. I looked in the logs and see this error:
org.apache.wicket.WicketRuntimeException: Expected to find in base markup: jar:file:/C:/Program%20Files/Inductive%20Automation/Ignition/data/jar-cache/com.inductiveautomation.opcua/__1026606207__opc-ua-gateway-8.0.4.jar!/com/inductiveautomation/ignition/gateway/opcua/client/connection/web/discovery/wizardsteps/AbstractDiscoveryWizardStep.html
I tried the same settings to try to add a second copy of the local ignition server, by specifying localhost, and had the same error. I am able to click the Advanced Configuration and add the host that way, but not through the discovery service.
Is there a way to get the discovery service web page to load/work, does anyone else have this problem? I tried this on Ignition, and Ignition Edge.
