OPC client freeze and tags no longer update after a brief connection lost
The networking broke at local switch and remote switch for 10-30 seconds.(Ignition server--local switch--remote switch--OPC server) Then the Ignition OPC client froze for hours until I restart the OPC module manually. Everything showed good, OPC client connection, tags quality, but tags no longer update anymore. I tried another OPC client tool and checked out the OPC server, it worked fine. I noticed this error because of the abnormal chart.
It happened twice. Version is 8.1.33.
I tried to enable the server diagnostics, but failed by "Diagnostics may not be supported by server."
Any advice? Should I upload any logs(which one...)
Thanks for any reply.
Same issue on 8.1.48.A third part OPC server. Tag quality is good; OPC connection is connected. Restart tag, not work; third part OPC client, works fine. Server Status currentTime params, update normally.
Easiest route for troubleshooting would be a Wireshark capture. Disable any security on the connection so it can be read.
