I have OPC COM Module (5.0.7) running on Ignition Edge (8.0.7) to Connect to Autosol ACM OPC Server (DA).
The connection connects and reads no problem. The issue I am having is it creates multiple client connections and causes errors when writing values. This is the only OPC Connection to this OPC Server. The issue happened this weekend, and by the time I found it, there was 75 clients connected to the Server - all from Ignition OPC COM.
Has anyone seen this before?
