Ignition 8.3.9
We connect to an opcua server for Video-based Automatic Incident Detection with a virtual IP Address.
Sometime we are disconnected, Ignition connection is FAULTED with the following error:
java.lang.Exception: session inactive: id=NodeId{ns=1, id=a7d319ac-7438-4f41-ac42-b9171f85ffa7} name=ignition_1793954736501
at com.inductiveautomation.ignition.gateway.opcua.client.connection.OpcUaConnection$MiloSessionActivityListener.onSessionInactive(OpcUaConnection.kt:460)
at org.eclipse.milo.opcua.sdk.client.session.SessionFsmFactory.lambda$configureActiveState$42(SessionFsmFactory.java:737)
at java.base/java.util.concurrent.CopyOnWriteArrayList.forEach(Unknown Source)
at org.eclipse.milo.opcua.sdk.client.session.SessionFsmFactory.lambda$configureActiveState$43(SessionFsmFactory.java:736)
We have to disable/enable the connection to reconnect.
We suspect the opcua server is non-transparent for the opcua client and we need to reconnect each time the virtual address switch.
@Kevin.Herron is the Exception normal for this use case ?
Can we force the connection to reconnect ?
