I'm trying to set up a new OPC Server from another Ignition gateway and after selecting the endpoint with security policy and mode, I get an Internal Error.
Can you check the Ignition Gateway logs for a more detailed error message?
One of the error shown is:
org.apache.wicket.markup.MarkupNotFoundException: Markup of type 'html' for component 'com.inductiveautomation.ignition.gateway.opcua.client.connection.web.discovery.wizardsteps.ManageCertificateStep' not found. Enable debug messages for org.apache.wicket.util.resource to get a list of all filenames tried: [ManageCertificateStep [Component id = view]]
at org.apache.wicket.MarkupContainer.getAssociatedMarkup(MarkupContainer.java:430)
at org.apache.wicket.MarkupContainer.getAssociatedMarkupStream(MarkupContainer.java:372)
at org.apache.wicket.markup.html.panel.AssociatedMarkupSourcingStrategy.renderHeadFromAssociatedMarkupFile(AssociatedMarkupSourcingStrategy.java:244)
at org.apache.wicket.markup.html.panel.AssociatedMarkupSourcingStrategy.renderHead(AssociatedMarkupSourcingStrategy.java:220)
at org.apache.wicket.Component.renderHead(Component.java:2675)
at org.apache.wicket.markup.renderStrategy.ChildFirstHeaderRenderStrategy$1.component(ChildFirstHeaderRenderStrategy.java:85)
at org.apache.wicket.markup.renderStrategy.DeepChildFirstVisitor.visit(DeepChildFirstVisitor.java:96)
at org.apache.wicket.markup.renderStrategy.DeepChildFirstVisitor.visit(DeepChildFirstVisitor.java:87)
at org.apache.wicket.markup.renderStrategy.DeepChildFirstVisitor.visit(DeepChildFirstVisitor.java:51)
at org.apache.wicket.markup.renderStrategy.ChildFirstHeaderRenderStrategy.renderChildHeaders(ChildFirstHeaderRenderStrategy.java:78)
at org.apache.wicket.markup.renderStrategy.ChildFirstHeaderRenderStrategy.renderHeader(ChildFirstHeaderRenderStrategy.java:57)
at org.apache.wicket.markup.html.internal.HtmlHeaderContainer.onComponentTagBody(HtmlHeaderContainer.java:170)
at org.apache.wicket.markup.html.panel.DefaultMarkupSourcingStrategy.onComponentTagBody(DefaultMarkupSourcingStrategy.java:71)
at org.apache.wicket.Component.internalRenderComponent(Component.java:2537)
at org.apache.wicket.MarkupContainer.onRender(MarkupContainer.java:1499)
at org.apache.wicket.Component.internalRender(Component.java:2367)
at org.apache.wicket.Component.render(Component.java:2295)
at org.apache.wicket.MarkupContainer.renderNext(MarkupContainer.java:1395)
at org.apache.wicket.MarkupContainer.renderAll(MarkupContainer.java:1560)
at org.apache.wicket.Page.onRender(Page.java:887)
at org.apache.wicket.markup.html.WebPage.onRender(WebPage.java:141)
at org.apache.wicket.Page.renderPage(Page.java:1024)
at org.apache.wicket.request.handler.render.WebPageRenderer.renderPage(WebPageRenderer.java:139)
at org.apache.wicket.request.handler.render.WebPageRenderer.respond(WebPageRenderer.java:284)
at org.apache.wicket.core.request.handler.RenderPageRequestHandler.respond(RenderPageRequestHandler.java:175)
at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:890)
at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:97)
at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:261)
at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:218)
at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:289)
at org.apache.wicket.protocol.http.WicketFilter.processRequestCycle(WicketFilter.java:259)
at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:201)
at org.apache.wicket.protocol.http.WicketFilter.doFilter(WicketFilter.java:282)
at org.eclipse.jetty.servlet.FilterHolder.doFilter(FilterHolder.java:210)
at org.eclipse.jetty.servlet.ServletHandler$Chain.doFilter(ServletHandler.java:1635)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:527)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:131)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:578)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:122)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:223)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1570)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:221)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1384)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:176)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:484)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1543)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:174)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1306)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:129)
at com.inductiveautomation.catapult.handlers.RemoteHostNameLookupHandler.handle(RemoteHostNameLookupHandler.java:121)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:301)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:51)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:141)
at org.eclipse.jetty.server.Server.handle(Server.java:563)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$0(HttpChannel.java:505)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:762)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:497)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:282)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:314)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:100)
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:558)
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:379)
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:146)
at org.eclipse.jetty.io.SelectableChannelEndPoint$1.run(SelectableChannelEndPoint.java:53)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.runTask(AdaptiveExecutionStrategy.java:416)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.consumeTask(AdaptiveExecutionStrategy.java:385)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.tryProduce(AdaptiveExecutionStrategy.java:272)
at org.eclipse.jetty.util.thread.strategy.AdaptiveExecutionStrategy.lambda$new$0(AdaptiveExecutionStrategy.java:140)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:411)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:969)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.doRunJob(QueuedThreadPool.java:1194)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1149)
Caused by: org.apache.wicket.WicketRuntimeException: Expected to find in base markup: jar:file:/C:/Program%20Files/Inductive%20Automation/Ignition/data/jar-cache/com.inductiveautomation.opcua/__4018877055__opc-ua-gateway-9.1.30.jar!/com/inductiveautomation/ignition/gateway/opcua/client/connection/web/discovery/wizardsteps/AbstractDiscoveryWizardStep.html
at org.apache.wicket.markup.MergedMarkup.merge(MergedMarkup.java:249)
at org.apache.wicket.markup.MergedMarkup.(MergedMarkup.java:87)
at org.apache.wicket.markup.loader.InheritedMarkupMarkupLoader.loadMarkup(InheritedMarkupMarkupLoader.java:82)
at org.apache.wicket.markup.loader.DefaultMarkupLoader.loadMarkup(DefaultMarkupLoader.java:52)
at org.apache.wicket.markup.MarkupFactory.loadMarkup(MarkupFactory.java:412)
at org.apache.wicket.markup.MarkupCache.loadMarkup(MarkupCache.java:448)
at org.apache.wicket.markup.MarkupCache.loadMarkupAndWatchForChanges(MarkupCache.java:544)
at org.apache.wicket.markup.MarkupCache.getMarkup(MarkupCache.java:305)
at org.apache.wicket.markup.MarkupFactory.getMarkup(MarkupFactory.java:236)
at org.apache.wicket.markup.MarkupFactory.getMarkup(MarkupFactory.java:194)
at org.apache.wicket.MarkupContainer.getAssociatedMarkup(MarkupContainer.java:405)
Another error shown is
If you stop the gateway, delete the .../Ignition/data/jar-cache folder, then start it again... should be fixed.
Just to be sure, delete this folder here after stopping the gateway:
C:\Program Files\Inductive Automation\Ignition\data\jar-cache
Is there other means to stop the gateway without admin access on the computer?
Yes, that's the folder.
I don't think you can stop the gateway without local admin access.
