I have a problem establishing a connection between Ignition and Topserver using OPC UA.
I have two instances of topserver running on two different servers. One topserver instance connects no problem at all. the other refuses to connect.
I have gone through all the Topserver settings and Ignition settings for the two connections and unable to find a difference. There is no difference bewteen the two installs or versions of topserver.
we are not running a firewall.
the ignition configuration instructions say that ignition will automatically enter a certificate into the trusted clients window of the OPC UA configuration for top server. This does not happen on the faulted connection. Manualy importing the certificate does not work either.
I am at a loss what to try next.
