Ignition 8.0.12
When I am adding a new OPC connection to the gateway with the gateway webbrowser, a new tagfolder is automatically added to ‘[System]Gateway/OPC/Connections’ with the same name as the added connection name.
This folder contains 2 booleans (Connected, Enabled) and a State string tag.
After editing this OPC connection name in de gateway webbrowser a new folder to ‘[System]Gateway/OPC/Connections’ is added with the new name only the original folder is not removed.
Is this correct?
How can I remove these not longer used (connection) tagfolders?
You shouldn’t have to do anything to remove these. This is a bug that we’ll have to fix.
Any update on this ticket?
It looks like as of 8.1.3 this should all work as expected.
I’m using version 8.1.7 and had 2 Kepware connections.
One is removed and the other is still active.
I see the removed connection as an empty folder in the system tags.
I’m using the view of the exchange for showing the gateway status:
I’ll open another ticket but I’m not able to reproduce this locally (8.1.9 nightly I guess). The connection’s folder and child immediately disappear from system tags when I delete the connection.
Can you upload a screenshot of your system tags from the Designer?
Okay I opened another ticket
Same issue here on 8.1.9
I also have the same problem with the database connections (Version 8.1.10).
Do you got any updates regarding this bug?
