OPC Connection to Another Ignition OPC UA Server on a different domain
Or in this case, because the other server is clearly configured to bind to “localhost”.
Replace “localhost” in that configuration with the IP (10.64.61.151?) of that server and then restart Ignition.
If you don’t manage to get this working soon support would be able to walk you through it pretty quick. Just make sure you call, not email.
