OPC connections working from gateway A but not from gateway B
I have an Ignition gateway A that's able to connect to a number of other Ignition OPC servers and Postgres databases. When I back up A and restore it to another machine B on the same network (using standard gwcmd to run the backup and restores), but with a different IP address, I can't connect to those servers or databases. Where should I start troubleshooting the connection failures? (I.e. where in the logs should I look, etc).
Not expecting a full solution here, just a sense of where to start debugging.
Certificates to be approved on both ends of OPC UA connections. Not part of backups, IIRC.
dang, aight -- are the certs tied to FQDN, hostname, etc?
Also how would I export/import them
Each gateway constructs a self-signed certificate for itself for OPC UA purposes. Look in the OPC security section. Also got to each of those servers to "trust" the new Ignition server.
Thanks -- i don't suppose there's any way to use gwcmd to export the pkey/keychain and import it to gateway B?
(I don't want to have to modify the keychains/trusted servers of the other systems)
I know there's an exportks and similar command set in GWCMD
Also, I'm assuming the DB connection issue is either also a cert or just some IP level firewalling?
I'd start by looking at the faults in the Gateway, there should be error messages and stack traces. The certs are a good lead for the OPC UA connections, not as common for the DB connections.
Great, in the logs of the gateway?
The Gateway status pages for these connections should tell you about the faults and let you see a stack trace.
