Hi, I'm struggling to connect to an OPCWorx server, which is provided by Red Lion Controls. This server is running on the same Windows 10 VM that my Ignition gateway (v8.3.9) is on. The progID shows up automatically when configuring the connection:
After saving the config, I get the error below. I'm able to successfully browse tags from this server using the Matrikon OPC Explorer. I went through (almost) all of the steps on this page: OPC COM | Ignition User Manual, with the exception of the "OPC Server DCOM Settings" section at the end since I'm unable to identify an entry corresponding with the OPC server.
In case it's relevant, I'm seeing a few DCOM events in the Windows Event Viewer like this:
A bit strange that the APPID and SID are not populated. Any suggestions on what I can look at next?
Jeremy
java.lang.IllegalStateException: The server did not indicate that it was ready to receive connections. at com.inductiveautomation.opccom.COMServerImpl$3.run(COMServerImpl.java:465) at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:557) at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source) at java.base/java.util.concurrent.FutureTask.run(Unknown Source) at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source) at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) at java.base/java.lang.Thread.run(Unknown Source)
I've used OPCExpert in the past to troubleshoot OPC-DA things. The free version runs four hours at a stretch. It might give you some insight.
Didactic warning ahead...
That particular error usually pops up because the Windows Security Center service is configured with a delayed startup. WscDataProtection tries to communicate early before wscsvc has finished starting. That can be fixed by turning of the DelayedAutoStart flag. IIRC, that has to be done through the registry editor.
I've also seen this happen if OneDrive is a startup app.
I registered both of the DLLs recommended (they were packaged with the OPCExpert software in the "General OPC Files" folder), but I get the same error upon closing and restarting OPCExpert.
Per your second suggestion, I tried setting the value of the registry entry Computer\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\wscsvc\DelayedAutoStart from 1 to 0. I have the same error in both the Ignition gateway and OPCExpert after rebooting my VM.
Also, for what it's worth, I'm able to connect and browse tags on the server if I DON'T run OPCExpert as admin. There's a warning when launching the software that running as a non-admin user can cause "unexpected failures", but it seems to be the opposite case for me.
Interestingly, I have the same behavior with the Matrikon OPC Explorer program. It works fine when run as a normal user, but I cannot connect or browse tags when running as admin.
Curious whether that indicates any possible issues for Ignition connecting?
Given ProgId populated that means windows can lookup the server from the registry but the fact it works with one user account but not admin (and probably Ignition cant via system) I think it's an issue where windows is spinning up a new copy of the server for each user so the one Ignition is connecting to isn't configured.
I finally got this working and the issue turned out to be a simple file permissions issue I goofed up within the Red Lion OPCWorx setup. The OPCWorx Server Configuration Tool generates an "OPC Server Database" file (extension .odx) which defines the device and tag information for the server. It appears that the OPC client (Ignition, OPC Expert, etc.) also needs access to this *.odx file.
Without giving it much thought, I had saved the .odx file to a shared folder on my virtual machine. In other words, a directory on my host machine that my VM has read/write access to. I suspect that only the logged-in, non-admin user has access to that directory, which is why I could browse my device tags with OPC Expert only if I DIDN'T run as admin. I moved the *.odx file to the VM's local hard drive (C:\), then both Ignition and OPC Expert (as admin) could browse the device.
@Nol - thanks for the info and the link. This makes perfect sense for OPC servers that run as Windows services, but apparently, Red Lion's OPCWorx only runs as an application (see this forum post). This explains why I couldn't find any record of it in the Component Services list.
