Issue:
Trying to get values from a remote kepserver into ignition edge via OPC DA. Ignition Edge OPC DA connection to a remote Kepware server fails with 0x80040154 (Class not registered) and E_ACCESSDENIED errors, despite successful tag reads using Matrikon OPC Explorer on the same Edge machine.
Steps Taken:
- DCOM and User Configuration:
- Ensured matching local admin user accounts on both Kepware and Edge machines.
- Configured DCOM permissions for OpcEnum and Kepware DCOM objects (Launch/Activation and Access for Everyone/ANONYMOUS LOGON).
- Set Ignition Edge service to run under a DCOM-authorized admin account.
- OPC Core Components:
- Installed both 32-bit and 64-bit OPC Core Components Redistributables on the Edge machine.
- Registered required 32-bit OPC DLLs using
regsvr32from SysWOW64.
- Registry Edits:
- Located the CLSID for
Kepware.KEPServerEX.V6on the Kepware server. - Created and merged
.regfiles on the Edge machine under both regular and WOW6432Node registry paths, including correct RemoteServerName (Kepware server’s computer name).
- Firewall:
- Opened TCP port 135 and dynamic ports 49152–65535 on both machines.
- Allowed OPCEnum.exe through the firewall.
- Testing and Validation:
- Used Matrikon OPC Explorer on the Edge machine to confirm OPC tags are readable from Kepware.
- Ignition Edge still fails with class registration errors and cannot browse/connect to the remote server.
Current Status:
- OPC access from third-party clients (Matrikon) works on the Edge machine.
- Ignition Edge OPC COM module still cannot connect to the remote Kepware server due to class registration errors, despite all registry, DCOM, and firewall steps above.
Request:
Looking for any additional steps or insights to resolve the Class not registered error for OPC DA connections in Ignition Edge, or confirmation if there are known limitations with 32-bit Kepware and 64-bit Ignition Edge DA connectivity.
