I've configured an OPC-DA connection from ignition to a 3rd party SCADA application to have ignition perform the scada application information for my project. (note that the 3rd part scada application is required and functions as a driver to addition physical equipment).
Ignition reads information from the 3rd party SCADA application successfully, but any write of data from ignition to the 3rd party SCADA application results in an Error message in ignition. This Error message says, '...Bad_Failure("A value passed to write was accepted but the output was clamped.")'. Is there a way to turn off (or ignore) this error message?
Thanks, Gus
