Hello,
I have a problem when I want to get tags from my OPC Server, I have the OPC WinCC Explorer that has all the tags that I want to create, but there doesn’t show me the tags, that in the reality exists.
Please can you help me to solve my problem
Best regards
Carito
In the gateway, if you go to Configure>Console, are there any error messages from around the time you browse?
Also, you might try the following: Edit your OPC connection, and select “Force DA 2”. Then refresh the opc browser in the designer and try again. This uses a different browse mechanism, and sometimes helps these sorts of problems.
Regards,
