Trying the write to the OPC item path through the script console using the following script
system.tag.write("a/b/c/d/IO-01/SLOT1/ch0.OpcItemPath","{PLCPath}DB500,X0.0")
The path does not bind when written through the console. The tag is in error.
However when the OPC item path is manually edited, binding is successful.
Need to bind a lot of tags so thought this was a better way rather than doing is manually.
Appreciate any help in this regard.
Cheers,
Sameer
