The Ignition OPC UA Server has malfunctioned.
Upon checking OPC Connections under config. There were no connections created (although I have had them connected for quite a while)
I then clicked ‘create new’ to create a new connection but was met with a blank page.
I clicked next and a message popped up.
“field ‘choice’ requered”
-There were no fields to fill out in prevous page… sigh
I then checked my modules’ where I found State : Faulted ([getstring(ENDPOINT_ADDRESS_LIST)]) must not be null
I then un-installed said module and re-installed, same fault re-occurred.
I am now to uninstall ignition in its entierty and re-install it again.
Unless:
Has anyone had the same problem, how did you solve this (did you solve it differently?)
Regards.
/ilmoe
