We have some remote sensors and are using two Opto 22 Groov Rios. I can add the first one as a UPC no issue and when adding the second one I am getting this message.
UaException: status=Bad_ConnectionRejected, message=io.netty.channel.AbstractChannel$AnnotatedConnectException: Connection refused: getsockopt: /10.3.56.12:14840
The first RIO I added was 10.3.56.11 and had no issue and went right through. I can pull both up by typing in the IP into the browser and all setting inside the device are exactly the same with the exception of the IP. I thought maybe I had a weird port on the ethernet switch so I went out and swapped were they were plugged up hoping the problem would follow. But I am still having the same issue as before. Any help would be appreciated.
