For OPC Server Connection Failover, can we configure a failover mode like the database connection ?
Standart : Standard failover mode means that this datasource will fail over when a connection cannot be retrieved, but when connectivity is restored, connections will again come from this datasource
STICKY : Sticky failover mode means that once this datasource fails over, connections will continue coming from the failover datasource until the failover datasource itself fails or the Gateway is restarted.
For the Attempts Before Failover parameter, what is the timeout value between attempts, can we modify it ?
