OPC Server Falted, Timing out
169.* addresses are APIPA numbers used when a machine cannot reach a DHCP server and there’s no manual IP address configuration. This can mean your Ignition service was configured when your network wasn’t plugged in or your DHCP server was slow to respond. You’ll have to manually configure that endpoint to your Ignition gateway’s actual address.
