My JSON sample:
[{"SN":[0,0,0,0,0,0,0,0,0,0],"Device_Type":315,"Nominal_Active_Power":125.0,"Output_Type":2,"Daily_Power_Yield":19.0,"Total_Power_Yield":48688,"Total_Running_Time":1278,"Internal_Temperature":36.7,"Total_Apparent_Power":8525,"Total_DC_Power":8.655001,"AB_Line_Voltage":606.2,"BC_Line_Voltage":608.60004,"CA_Line_Voltage":606.3,"Phase_A_Voltage":606.2,"Phase_B_Voltage":608.60004,"Phase_C_Voltage":606.3,"Phase_A_Current":9.0,"Phase_B_Current":9.0,"Phase_C_Current":9.1,"Total_Active_Power":8.525001,"Total_Reactive_Power":220,"Power_Factor":100.0,"Grid_frequency_01":50.0,"Work_State_AP1":0,"Alarm_Year":0,"Alarm_Month":0,"Alarm_Day":0,"Alarm_Hour":0,"Alarm_Minute":0,"Alarm_Second":0,"Alarm_Code":0,"Nominal_Reactive":75.0,"Insulation_Resistance":233,"Active_Power_Setpoint":125000,"Reactive_Power_Setpoint":0,"Work_State_AP2":131073,"Meter_Power":-1,"Meter_A_Phase_Power":-1,"Meter_B_Phase_Power":-1,"Meter_C_Phase_power":-1,"Load_Power":-1,"Daily_Export_Energy":4.294967295E8,"Total_Export_Energy":4.294967295E8,"Daily_Import_Energy":4.294967295E8,"Total_Import_Energy":4.294967295E8,"Daily_Energy_Consumption":4.294967295E8,"Total_Energy_Consumption":4.294967295E8,"Daily_Running_Time":296,"Preset_Country":16,"MPPT_1_Voltage":1012.0,"MPPT_1_Current":8.6,"MPPT_2_Voltage":6553.5,"MPPT_2_Current":6553.5,"MPPT_3_Voltage":6553.5,"MPPT_3_Current":6553.5,"MPPT_4_Voltage":6553.5,"MPPT_4_Current":6553.5,"MPPT_5_Voltage":6553.5,"MPPT_5_Current":6553.5,"MPPT_6_Voltage":6553.5,"MPPT_6_Current":6553.5,"MPPT_7_Voltage":6553.5,"MPPT_7_Current":6553.5,"MPPT_8_Voltage":6553.5,"MPPT_8_Current":6553.5,"MPPT_9_Voltage":6553.5,"MPPT_9_Current":6553.5,"MPPT_10_Voltage":6553.5,"MPPT_10_Current":6553.5,"MPPT_11_Voltage":6553.5,"MPPT_11_Current":6553.5,"MPPT_12_Voltage":6553.5,"MPPT_12_Current":6553.5,"Monthly_Power_Yields":2084.1,"Total_Power_Yields":1.843920903E9,"Negative_Voltage_Ground":-5060.0,"Bus_Voltage":10120.0,"Grid_Frequency_001":5001.0,"PID_work_state":0,"PID_alarm_code":0,"String_1_Current":655.35,"String_2_Current":655.35,"String_3_Current":655.35,"String_4_Current":655.35,"String_5_Current":655.35,"String_6_Current":655.35,"String_7_Current":655.35,"String_8_Current":655.35,"String_9_Current":655.35,"String_10_Current":655.35,"String_11_Current":655.35,"String_12_Current":655.35,"String_13_Current":655.35,"String_14_Current":655.35,"String_15_Current":655.35,"String_16_Current":0.01,"String_17_Current":0.01,"String_18_Current":655.35,"String_19_Current":655.35,"String_20_Current":281.36,"String_21_Current":0.07,"String_22_Current":604.76,"String_23_Current":101.2,"String_24_Current":50.01,"Year":2022,"Month":11,"Day":14,"Hour":13,"Minute":34,"Second":23,"Start":true,"Stop":false,"Power_limitations_On":true,"Power_limitations_Off":false,"Power_limitations_value":100.0,"Export_power_On":false,"Export_power_Off":false,"Export_power_value":65535,"C_Transformer_output":0,"C_Transformer_range":0,"Current_Transformer":0,"Export_power_percentage":0.0,"Installed_PV_Power":0.0,"Power_Factor_Set":0.0,"Scheduling_to_AAO":0,"Night_SVG_Switch":0,"Reactive_Adjustment_Mode":0,"Reactive_Adjust_Off":false,"Reactive_Adjust_Valid":false,"Reactive_Adjust_Perc":false,"Reactive_Power_Percentage":0.0,"Power_Limit_Adjust":0.0,"Reactive_Power_Adjust":0.0,"PID_Recovery":0,"Anti_PID":0,"Full_Day_PID":0,"Set_Start":false,"Set_Stop":false,"Work_RUN":true}, {"SN":[0,0,0,0,0,0,0,0,0,0],"Device_Type":315,"Nominal_Active_Power":125.0,"Output_Type":2,"Daily_Power_Yield":18.0,"Total_Power_Yield":520497,"Total_Running_Time":15800,"Internal_Temperature":38.100002,"Total_Apparent_Power":8088,"Total_DC_Power":8.211,"AB_Line_Voltage":606.9,"BC_Line_Voltage":608.5,"CA_Line_Voltage":605.3,"Phase_A_Voltage":606.9,"Phase_B_Voltage":608.5,"Phase_C_Voltage":605.3,"Phase_A_Current":8.5,"Phase_B_Current":8.5,"Phase_C_Current":8.6,"Total_Active_Power":8.088,"Total_Reactive_Power":220,"Power_Factor":100.0,"Grid_frequency_01":50.0,"Work_State_AP1":0,"Alarm_Year":0,"Alarm_Month":0,"Alarm_Day":0,"Alarm_Hour":0,"Alarm_Minute":0,"Alarm_Second":0,"Alarm_Code":0,"Nominal_Reactive":75.0,"Insulation_Resistance":253,"Active_Power_Setpoint":125000,"Reactive_Power_Setpoint":0,"Work_State_AP2":131073,"Meter_Power":-1,"Meter_A_Phase_Power":-1,"Meter_B_Phase_Power":-1,"Meter_C_Phase_power":-1,"Load_Power":-1,"Daily_Export_Energy":4.294967295E8,"Total_Export_Energy":4.294967295E8,"Daily_Import_Energy":4.294967295E8,"Total_Import_Energy":4.294967295E8,"Daily_Energy_Consumption":4.294967295E8,"Total_Energy_Consumption":4.294967295E8,"Daily_Running_Time":301,"Preset_Country":16,"MPPT_1_Voltage":1021.4,"MPPT_1_Current":7.9,"MPPT_2_Voltage":6553.5,"MPPT_2_Current":6553.5,"MPPT_3_Voltage":6553.5,"MPPT_3_Current":6553.5,"MPPT_4_Voltage":6553.5,"MPPT_4_Current":6553.5,"MPPT_5_Voltage":6553.5,"MPPT_5_Current":6553.5,"MPPT_6_Voltage":6553.5,"MPPT_6_Current":6553.5,"MPPT_7_Voltage":6553.5,"MPPT_7_Current":6553.5,"MPPT_8_Voltage":6553.5,"MPPT_8_Current":6553.5,"MPPT_9_Voltage":6553.5,"MPPT_9_Current":6553.5,"MPPT_10_Voltage":6553.5,"MPPT_10_Current":6553.5,"MPPT_11_Voltage":6553.5,"MPPT_11_Current":6553.5,"MPPT_12_Voltage":6553.5,"MPPT_12_Current":6553.5,"Monthly_Power_Yields":1944.7,"Total_Power_Yields":1.810890831E9,"Negative_Voltage_Ground":-5118.0,"Bus_Voltage":10214.0,"Grid_Frequency_001":5001.0,"PID_work_state":0,"PID_alarm_code":0,"String_1_Current":655.35,"String_2_Current":655.35,"String_3_Current":655.35,"String_4_Current":655.35,"String_5_Current":655.35,"String_6_Current":655.35,"String_7_Current":655.35,"String_8_Current":655.35,"String_9_Current":655.35,"String_10_Current":655.35,"String_11_Current":655.35,"String_12_Current":655.35,"String_13_Current":655.35,"String_14_Current":655.35,"String_15_Current":655.35,"String_16_Current":0.01,"String_17_Current":0.01,"String_18_Current":655.35,"String_19_Current":655.35,"String_20_Current":276.32,"String_21_Current":0.78999996,"String_22_Current":604.18,"String_23_Current":102.14,"String_24_Current":50.01,"Year":2022,"Month":11,"Day":14,"Hour":12,"Minute":27,"Second":37,"Start":true,"Stop":false,"Power_limitations_On":true,"Power_limitations_Off":false,"Power_limitations_value":100.0,"Export_power_On":false,"Export_power_Off":false,"Export_power_value":65535,"C_Transformer_output":0,"C_Transformer_range":0,"Current_Transformer":0,"Export_power_percentage":0.0,"Installed_PV_Power":0.0,"Power_Factor_Set":0.0,"Scheduling_to_AAO":0,"Night_SVG_Switch":0,"Reactive_Adjustment_Mode":0,"Reactive_Adjust_Off":false,"Reactive_Adjust_Valid":false,"Reactive_Adjust_Perc":false,"Reactive_Power_Percentage":0.0,"Power_Limit_Adjust":0.0,"Reactive_Power_Adjust":0.0,"PID_Recovery":0,"Anti_PID":0,"Full_Day_PID":0,"Set_Start":false,"Set_Stop":false,"Work_RUN":true}, {"SN":[0,0,0,0,0,0,0,0,0,0],"Device_Type":315,"Nominal_Active_Power":125.0,"Output_Type":2,"Daily_Power_Yield":20.9,"Total_Power_Yield":594402,"Total_Running_Time":16154,"Internal_Temperature":38.0,"Total_Apparent_Power":9338,"Total_DC_Power":9.4800005,"AB_Line_Voltage":607.10004,"BC_Line_Voltage":608.5,"CA_Line_Voltage":605.4,"Phase_A_Voltage":607.10004,"Phase_B_Voltage":608.5,"Phase_C_Voltage":605.4,"Phase_A_Current":9.7,"Phase_B_Current":9.7,"Phase_C_Current":9.7,"Total_Active_Power":9.338,"Total_Reactive_Power":262,"Power_Factor":100.0,"Grid_frequency_01":50.0,"Work_State_AP1":0,"Alarm_Year":0,"Alarm_Month":0,"Alarm_Day":0,"Alarm_Hour":0,"Alarm_Minute":0,"Alarm_Second":0,"Alarm_Code":0,"Nominal_Reactive":75.0,"Insulation_Resistance":227,"Active_Power_Setpoint":125000,"Reactive_Power_Setpoint":0,"Work_State_AP2":131073,"Meter_Power":-1,"Meter_A_Phase_Power":-1,"Meter_B_Phase_Power":-1,"Meter_C_Phase_power":-1,"Load_Power":-1,"Daily_Export_Energy":4.294967295E8,"Total_Export_Energy":4.294967295E8,"Daily_Import_Energy":4.294967295E8,"Total_Import_Energy":4.294967295E8,"Daily_Energy_Consumption":4.294967295E8,"Total_Energy_Consumption":4.294967295E8,"Daily_Running_Time":298,"Preset_Country":16,"MPPT_1_Voltage":1022.2,"MPPT_1_Current":9.3,"MPPT_2_Voltage":6553.5,"MPPT_2_Current":6553.5,"MPPT_3_Voltage":6553.5,"MPPT_3_Current":6553.5,"MPPT_4_Voltage":6553.5,"MPPT_4_Current":6553.5,"MPPT_5_Voltage":6553.5,"MPPT_5_Current":6553.5,"MPPT_6_Voltage":6553.5,"MPPT_6_Current":6553.5,"MPPT_7_Voltage":6553.5,"MPPT_7_Current":6553.5,"MPPT_8_Voltage":6553.5,"MPPT_8_Current":6553.5,"MPPT_9_Voltage":6553.5,"MPPT_9_Current":6553.5,"MPPT_10_Voltage":6553.5,"MPPT_10_Current":6553.5,"MPPT_11_Voltage":6553.5,"MPPT_11_Current":6553.5,"MPPT_12_Voltage":6553.5,"MPPT_12_Current":6553.5,"Monthly_Power_Yields":2266.8,"Total_Power_Yields":3.000827994E9,"Negative_Voltage_Ground":-5134.0,"Bus_Voltage":10222.0,"Grid_Frequency_001":5001.0,"PID_work_state":0,"PID_alarm_code":0,"String_1_Current":655.35,"String_2_Current":655.35,"String_3_Current":655.35,"String_4_Current":655.35,"String_5_Current":655.35,"String_6_Current":655.35,"String_7_Current":655.35,"String_8_Current":655.35,"String_9_Current":655.35,"String_10_Current":655.35,"String_11_Current":655.35,"String_12_Current":655.35,"String_13_Current":655.35,"String_14_Current":655.35,"String_15_Current":655.35,"String_16_Current":0.01,"String_17_Current":0.01,"String_18_Current":655.35,"String_19_Current":655.35,"String_20_Current":457.88998,"String_21_Current":0.9,"String_22_Current":604.01996,"String_23_Current":102.22,"String_24_Current":50.01,"Year":2022,"Month":11,"Day":14,"Hour":12,"Minute":30,"Second":52,"Start":true,"Stop":false,"Power_limitations_On":true,"Power_limitations_Off":false,"Power_limitations_value":100.0,"Export_power_On":false,"Export_power_Off":false,"Export_power_value":65535,"C_Transformer_output":0,"C_Transformer_range":0,"Current_Transformer":0,"Export_power_percentage":0.0,"Installed_PV_Power":0.0,"Power_Factor_Set":0.0,"Scheduling_to_AAO":0,"Night_SVG_Switch":0,"Reactive_Adjustment_Mode":0,"Reactive_Adjust_Off":false,"Reactive_Adjust_Valid":false,"Reactive_Adjust_Perc":false,"Reactive_Power_Percentage":0.0,"Power_Limit_Adjust":0.0,"Reactive_Power_Adjust":0.0,"PID_Recovery":0,"Anti_PID":0,"Full_Day_PID":0,"Set_Start":false,"Set_Stop":false,"Work_RUN":true}, {"SN":[0,0,0,0,0,0,0,0,0,0],"Device_Type":315,"Nominal_Active_Power":125.0,"Output_Type":2,"Daily_Power_Yield":17.9,"Total_Power_Yield":535188,"Total_Running_Time":15802,"Internal_Temperature":38.9,"Total_Apparent_Power":8063,"Total_DC_Power":8.186001,"AB_Line_Voltage":607.3,"BC_Line_Voltage":607.0,"CA_Line_Voltage":604.4,"Phase_A_Voltage":607.3,"Phase_B_Voltage":607.0,"Phase_C_Voltage":604.4,"Phase_A_Current":8.5,"Phase_B_Current":8.5,"Phase_C_Current":8.6,"Total_Active_Power":8.063001,"Total_Reactive_Power":221,"Power_Factor":100.0,"Grid_frequency_01":50.0,"Work_State_AP1":0,"Alarm_Year":0,"Alarm_Month":0,"Alarm_Day":0,"Alarm_Hour":0,"Alarm_Minute":0,"Alarm_Second":0,"Alarm_Code":0,"Nominal_Reactive":75.0,"Insulation_Resistance":104,"Active_Power_Setpoint":125000,"Reactive_Power_Setpoint":0,"Work_State_AP2":131073,"Meter_Power":-1,"Meter_A_Phase_Power":-1,"Meter_B_Phase_Power":-1,"Meter_C_Phase_power":-1,"Load_Power":-1,"Daily_Export_Energy":4.294967295E8,"Total_Export_Energy":4.294967295E8,"Daily_Import_Energy":4.294967295E8,"Total_Import_Energy":4.294967295E8,"Daily_Energy_Consumption":4.294967295E8,"Total_Energy_Consumption":4.294967295E8,"Daily_Running_Time":296,"Preset_Country":16,"MPPT_1_Voltage":1018.0,"MPPT_1_Current":8.0,"MPPT_2_Voltage":6553.5,"MPPT_2_Current":6553.5,"MPPT_3_Voltage":6553.5,"MPPT_3_Current":6553.5,"MPPT_4_Voltage":6553.5,"MPPT_4_Current":6553.5,"MPPT_5_Voltage":6553.5,"MPPT_5_Current":6553.5,"MPPT_6_Voltage":6553.5,"MPPT_6_Current":6553.5,"MPPT_7_Voltage":6553.5,"MPPT_7_Current":6553.5,"MPPT_8_Voltage":6553.5,"MPPT_8_Current":6553.5,"MPPT_9_Voltage":6553.5,"MPPT_9_Current":6553.5,"MPPT_10_Voltage":6553.5,"MPPT_10_Current":6553.5,"MPPT_11_Voltage":6553.5,"MPPT_11_Current":6553.5,"MPPT_12_Voltage":6553.5,"MPPT_12_Current":6553.5,"Monthly_Power_Yields":1998.9,"Total_Power_Yields":2.848522321E9,"Negative_Voltage_Ground":-5086.0,"Bus_Voltage":10180.0,"Grid_Frequency_001":5000.0,"PID_work_state":0,"PID_alarm_code":0,"String_1_Current":655.35,"String_2_Current":655.35,"String_3_Current":655.35,"String_4_Current":655.35,"String_5_Current":655.35,"String_6_Current":655.35,"String_7_Current":655.35,"String_8_Current":655.35,"String_9_Current":655.35,"String_10_Current":655.35,"String_11_Current":655.35,"String_12_Current":655.35,"String_13_Current":655.35,"String_14_Current":655.35,"String_15_Current":655.35,"String_16_Current":0.01,"String_17_Current":0.01,"String_18_Current":655.35,"String_19_Current":655.35,"String_20_Current":434.65,"String_21_Current":0.81,"String_22_Current":604.5,"String_23_Current":101.799995,"String_24_Current":50.0,"Year":2022,"Month":11,"Day":14,"Hour":12,"Minute":28,"Second":51,"Start":true,"Stop":false,"Power_limitations_On":true,"Power_limitations_Off":false,"Power_limitations_value":100.0,"Export_power_On":false,"Export_power_Off":false,"Export_power_value":65535,"C_Transformer_output":0,"C_Transformer_range":0,"Current_Transformer":0,"Export_power_percentage":0.0,"Installed_PV_Power":0.0,"Power_Factor_Set":0.0,"Scheduling_to_AAO":0,"Night_SVG_Switch":0,"Reactive_Adjustment_Mode":0,"Reactive_Adjust_Off":false,"Reactive_Adjust_Valid":false,"Reactive_Adjust_Perc":false,"Reactive_Power_Percentage":0.0,"Power_Limit_Adjust":0.0,"Reactive_Power_Adjust":0.0,"PID_Recovery":0,"Anti_PID":0,"Full_Day_PID":0,"Set_Start":false,"Set_Stop":false,"Work_RUN":true}, {"SN":[0,0,0,0,0,0,0,0,0,0],"Device_Type":315,"Nominal_Active_Power":125.0,"Output_Type":2,"Daily_Power_Yield":19.4,"Total_Power_Yield":561431,"Total_Running_Time":16120,"Internal_Temperature":38.3,"Total_Apparent_Power":8712,"Total_DC_Power":8.845,"AB_Line_Voltage":607.3,"BC_Line_Voltage":607.3,"CA_Line_Voltage":605.4,"Phase_A_Voltage":607.3,"Phase_B_Voltage":607.3,"Phase_C_Voltage":605.4,"Phase_A_Current":9.2,"Phase_B_Current":9.2,"Phase_C_Current":9.3,"Total_Active_Power":8.712001,"Total_Reactive_Power":235,"Power_Factor":100.0,"Grid_frequency_01":50.0,"Work_State_AP1":0,"Alarm_Year":0,"Alarm_Month":0,"Alarm_Day":0,"Alarm_Hour":0,"Alarm_Minute":0,"Alarm_Second":0,"Alarm_Code":0,"Nominal_Reactive":75.0,"Insulation_Resistance":249,"Active_Power_Setpoint":125000,"Reactive_Power_Setpoint":0,"Work_State_AP2":131073,"Meter_Power":-1,"Meter_A_Phase_Power":-1,"Meter_B_Phase_Power":-1,"Meter_C_Phase_power":-1,"Load_Power":-1,"Daily_Export_Energy":4.294967295E8,"Total_Export_Energy":4.294967295E8,"Daily_Import_Energy":4.294967295E8,"Total_Import_Energy":4.294967295E8,"Daily_Energy_Consumption":4.294967295E8,"Total_Energy_Consumption":4.294967295E8,"Daily_Running_Time":297,"Preset_Country":16,"MPPT_1_Voltage":1022.5,"MPPT_1_Current":8.7,"MPPT_2_Voltage":6553.5,"MPPT_2_Current":6553.5,"MPPT_3_Voltage":6553.5,"MPPT_3_Current":6553.5,"MPPT_4_Voltage":6553.5,"MPPT_4_Current":6553.5,"MPPT_5_Voltage":6553.5,"MPPT_5_Current":6553.5,"MPPT_6_Voltage":6553.5,"MPPT_6_Current":6553.5,"MPPT_7_Voltage":6553.5,"MPPT_7_Current":6553.5,"MPPT_8_Voltage":6553.5,"MPPT_8_Current":6553.5,"MPPT_9_Voltage":6553.5,"MPPT_9_Current":6553.5,"MPPT_10_Voltage":6553.5,"MPPT_10_Current":6553.5,"MPPT_11_Voltage":6553.5,"MPPT_11_Current":6553.5,"MPPT_12_Voltage":6553.5,"MPPT_12_Current":6553.5,"Monthly_Power_Yields":2207.7000000000003,"Total_Power_Yields":2.867265621E9,"Negative_Voltage_Ground":-5130.0,"Bus_Voltage":10225.0,"Grid_Frequency_001":5000.0,"PID_work_state":0,"PID_alarm_code":0,"String_1_Current":655.35,"String_2_Current":655.35,"String_3_Current":655.35,"String_4_Current":655.35,"String_5_Current":655.35,"String_6_Current":655.35,"String_7_Current":655.35,"String_8_Current":655.35,"String_9_Current":655.35,"String_10_Current":655.35,"String_11_Current":655.35,"String_12_Current":655.35,"String_13_Current":655.35,"String_14_Current":655.35,"String_15_Current":655.35,"String_16_Current":0.01,"String_17_Current":0.01,"String_18_Current":655.35,"String_19_Current":655.35,"String_20_Current":437.50998,"String_21_Current":0.84999996,"String_22_Current":604.06,"String_23_Current":102.25,"String_24_Current":50.0,"Year":2022,"Month":11,"Day":14,"Hour":12,"Minute":32,"Second":27,"Start":true,"Stop":false,"Power_limitations_On":true,"Power_limitations_Off":false,"Power_limitations_value":100.0,"Export_power_On":false,"Export_power_Off":false,"Export_power_value":65535,"C_Transformer_output":0,"C_Transformer_range":0,"Current_Transformer":0,"Export_power_percentage":0.0,"Installed_PV_Power":0.0,"Power_Factor_Set":0.0,"Scheduling_to_AAO":0,"Night_SVG_Switch":0,"Reactive_Adjustment_Mode":0,"Reactive_Adjust_Off":false,"Reactive_Adjust_Valid":false,"Reactive_Adjust_Perc":false,"Reactive_Power_Percentage":0.0,"Power_Limit_Adjust":0.0,"Reactive_Power_Adjust":0.0,"PID_Recovery":0,"Anti_PID":0,"Full_Day_PID":0,"Set_Start":false,"Set_Stop":false,"Work_RUN":true}, {"SN":[0,0,0,0,0,0,0,0,0,0],"Device_Type":315,"Nominal_Active_Power":125.0,"Output_Type":2,"Daily_Power_Yield":20.1,"Total_Power_Yield":530040,"Total_Running_Time":15445,"Internal_Temperature":34.7,"Total_Apparent_Power":9006,"Total_DC_Power":9.143001,"AB_Line_Voltage":608.0,"BC_Line_Voltage":608.60004,"CA_Line_Voltage":605.8,"Phase_A_Voltage":608.0,"Phase_B_Voltage":608.60004,"Phase_C_Voltage":605.8,"Phase_A_Current":9.3,"Phase_B_Current":9.3,"Phase_C_Current":9.400001,"Total_Active_Power":9.0060005,"Total_Reactive_Power":234,"Power_Factor":100.0,"Grid_frequency_01":50.0,"Work_State_AP1":0,"Alarm_Year":0,"Alarm_Month":0,"Alarm_Day":0,"Alarm_Hour":0,"Alarm_Minute":0,"Alarm_Second":0,"Alarm_Code":0,"Nominal_Reactive":75.0,"Insulation_Resistance":227,"Active_Power_Setpoint":125000,"Reactive_Power_Setpoint":0,"Work_State_AP2":131073,"Meter_Power":-1,"Meter_A_Phase_Power":-1,"Meter_B_Phase_Power":-1,"Meter_C_Phase_power":-1,"Load_Power":-1,"Daily_Export_Energy":4.294967295E8,"Total_Export_Energy":4.294967295E8,"Daily_Import_Energy":4.294967295E8,"Total_Import_Energy":4.294967295E8,"Daily_Energy_Consumption":4.294967295E8,"Total_Energy_Consumption":4.294967295E8,"Daily_Running_Time":301,"Preset_Country":16,"MPPT_1_Voltage":1022.10004,"MPPT_1_Current":8.900001,"MPPT_2_Voltage":6553.5,"MPPT_2_Current":6553.5,"MPPT_3_Voltage":6553.5,"MPPT_3_Current":6553.5,"MPPT_4_Voltage":6553.5,"MPPT_4_Current":6553.5,"MPPT_5_Voltage":6553.5,"MPPT_5_Current":6553.5,"MPPT_6_Voltage":6553.5,"MPPT_6_Current":6553.5,"MPPT_7_Voltage":6553.5,"MPPT_7_Current":6553.5,"MPPT_8_Voltage":6553.5,"MPPT_8_Current":6553.5,"MPPT_9_Voltage":6553.5,"MPPT_9_Current":6553.5,"MPPT_10_Voltage":6553.5,"MPPT_10_Current":6553.5,"MPPT_11_Voltage":6553.5,"MPPT_11_Current":6553.5,"MPPT_12_Voltage":6553.5,"MPPT_12_Current":6553.5,"Monthly_Power_Yields":2241.4,"Total_Power_Yields":3.769892944E9,"Negative_Voltage_Ground":-5104.0,"Bus_Voltage":10221.0,"Grid_Frequency_001":5000.0,"PID_work_state":0,"PID_alarm_code":0,"String_1_Current":655.35,"String_2_Current":655.35,"String_3_Current":655.35,"String_4_Current":655.35,"String_5_Current":655.35,"String_6_Current":655.35,"String_7_Current":655.35,"String_8_Current":655.35,"String_9_Current":655.35,"String_10_Current":655.35,"String_11_Current":655.35,"String_12_Current":655.35,"String_13_Current":655.35,"String_14_Current":655.35,"String_15_Current":655.35,"String_16_Current":0.01,"String_17_Current":0.01,"String_18_Current":655.35,"String_19_Current":655.35,"String_20_Current":575.24,"String_21_Current":0.79999995,"String_22_Current":604.32,"String_23_Current":102.21,"String_24_Current":50.0,"Year":2022,"Month":11,"Day":14,"Hour":12,"Minute":29,"Second":23,"Start":true,"Stop":false,"Power_limitations_On":true,"Power_limitations_Off":false,"Power_limitations_value":100.0,"Export_power_On":false,"Export_power_Off":false,"Export_power_value":65535,"C_Transformer_output":0,"C_Transformer_range":0,"Current_Transformer":0,"Export_power_percentage":0.0,"Installed_PV_Power":0.0,"Power_Factor_Set":0.0,"Scheduling_to_AAO":0,"Night_SVG_Switch":0,"Reactive_Adjustment_Mode":0,"Reactive_Adjust_Off":false,"Reactive_Adjust_Valid":false,"Reactive_Adjust_Perc":false,"Reactive_Power_Percentage":0.0,"Power_Limit_Adjust":0.0,"Reactive_Power_Adjust":0.0,"PID_Recovery":0,"Anti_PID":0,"Full_Day_PID":0,"Set_Start":false,"Set_Stop":false,"Work_RUN":true}, {"SN":[0,0,0,0,0,0,0,0,0,0],"Device_Type":315,"Nominal_Active_Power":125.0,"Output_Type":2,"Daily_Power_Yield":19.800001,"Total_Power_Yield":554038,"Total_Running_Time":16240,"Internal_Temperature":35.600002,"Total_Apparent_Power":8889,"Total_DC_Power":9.024,"AB_Line_Voltage":608.10004,"BC_Line_Voltage":608.7,"CA_Line_Voltage":605.7,"Phase_A_Voltage":608.10004,"Phase_B_Voltage":608.7,"Phase_C_Voltage":605.7,"Phase_A_Current":9.400001,"Phase_B_Current":9.400001,"Phase_C_Current":9.400001,"Total_Active_Power":8.889001,"Total_Reactive_Power":200,"Power_Factor":100.0,"Grid_frequency_01":49.9,"Work_State_AP1":0,"Alarm_Year":0,"Alarm_Month":0,"Alarm_Day":0,"Alarm_Hour":0,"Alarm_Minute":0,"Alarm_Second":0,"Alarm_Code":0,"Nominal_Reactive":75.0,"Insulation_Resistance":169,"Active_Power_Setpoint":125000,"Reactive_Power_Setpoint":0,"Work_State_AP2":131073,"Meter_Power":-1,"Meter_A_Phase_Power":-1,"Meter_B_Phase_Power":-1,"Meter_C_Phase_power":-1,"Load_Power":-1,"Daily_Export_Energy":4.294967295E8,"Total_Export_Energy":4.294967295E8,"Daily_Import_Energy":4.294967295E8,"Total_Import_Energy":4.294967295E8,"Daily_Energy_Consumption":4.294967295E8,"Total_Energy_Consumption":4.294967295E8,"Daily_Running_Time":301,"Preset_Country":16,"MPPT_1_Voltage":1008.10004,"MPPT_1_Current":9.0,"MPPT_2_Voltage":6553.5,"MPPT_2_Current":6553.5,"MPPT_3_Voltage":6553.5,"MPPT_3_Current":6553.5,"MPPT_4_Voltage":6553.5,"MPPT_4_Current":6553.5,"MPPT_5_Voltage":6553.5,"MPPT_5_Current":6553.5,"MPPT_6_Voltage":6553.5,"MPPT_6_Current":6553.5,"MPPT_7_Voltage":6553.5,"MPPT_7_Current":6553.5,"MPPT_8_Voltage":6553.5,"MPPT_8_Current":6553.5,"MPPT_9_Voltage":6553.5,"MPPT_9_Current":6553.5,"MPPT_10_Voltage":6553.5,"MPPT_10_Current":6553.5,"MPPT_11_Voltage":6553.5,"MPPT_11_Current":6553.5,"MPPT_12_Voltage":6553.5,"MPPT_12_Current":6553.5,"Monthly_Power_Yields":2195.3,"Total_Power_Yields":2.31741858E9,"Negative_Voltage_Ground":-5043.0,"Bus_Voltage":10081.0,"Grid_Frequency_001":4999.0,"PID_work_state":0,"PID_alarm_code":0,"String_1_Current":655.35,"String_2_Current":655.35,"String_3_Current":655.35,"String_4_Current":655.35,"String_5_Current":655.35,"String_6_Current":655.35,"String_7_Current":655.35,"String_8_Current":655.35,"String_9_Current":655.35,"String_10_Current":655.35,"String_11_Current":655.35,"String_12_Current":655.35,"String_13_Current":655.35,"String_14_Current":655.35,"String_15_Current":655.35,"String_16_Current":0.01,"String_17_Current":0.01,"String_18_Current":655.35,"String_19_Current":655.35,"String_20_Current":353.61,"String_21_Current":0.84,"String_22_Current":604.93,"String_23_Current":100.81,"String_24_Current":49.989998,"Year":2022,"Month":11,"Day":14,"Hour":12,"Minute":25,"Second":46,"Start":true,"Stop":false,"Power_limitations_On":true,"Power_limitations_Off":false,"Power_limitations_value":100.0,"Export_power_On":false,"Export_power_Off":false,"Export_power_value":65535,"C_Transformer_output":0,"C_Transformer_range":0,"Current_Transformer":0,"Export_power_percentage":0.0,"Installed_PV_Power":0.0,"Power_Factor_Set":0.0,"Scheduling_to_AAO":0,"Night_SVG_Switch":0,"Reactive_Adjustment_Mode":0,"Reactive_Adjust_Off":false,"Reactive_Adjust_Valid":false,"Reactive_Adjust_Perc":false,"Reactive_Power_Percentage":0.0,"Power_Limit_Adjust":0.0,"Reactive_Power_Adjust":0.0,"PID_Recovery":0,"Anti_PID":0,"Full_Day_PID":0,"Set_Start":false,"Set_Stop":false,"Work_RUN":true}]
