We have some non-Ignition applications using Ignition’s OPC-UA server as their data source. We are thinking that the application will need to be able to tell if/when the Master Ignition gateway has failed over to the Backup. We realize that if the server stops responding we should just switch over to the backup, but if the gateway is up and active is there a way to read this status from the OPC-UA server?
Thank you
