I created an OPC tag that is link to an item from my plc which was created with an OPC server. I pass this OPC tag to a pop up window. When I click on a button in the pop up window, I set the OPC tag to True with this line of code in the script :
event.source.parent.fvnr.commands.man_start_stop = True
The value in the PLC changes most of the time, but sometime, it dosen't. I need to close the pop up window, then re-open it. What is the issue? Is there a better way to change the value of the item?
Thank you!
