Hi everyone,
I need to assign OPC tags to a memory tag (Dataset type) inside of a Data Type Structure, is that possible? And how? Please.
Hi everyone,
I’m sorry, I have no idea what you are trying to do.
More details usually yield better results. Examples and possibly screenshots, along with what you have tried so far, are usually welcome.
HI,
Did you find solution? I’m stuck with same problem.
As @JordanCClark mentioned, without some more detail about what you’re trying to accomplish, the ‘how’ is very broad. What you’ve posted is one option. Another would be using queries to load a database and then pull that database to a database tag with a single query.
Its all a matter of the size and scope of the work you are trying to do.
Can you provide more details?
Thank you,
I’ll check with my datasets.
