Hello all,
I encounter a problem with the in-built OPC browser (not the tag browser) when trying to browse a specific folder/branch of a SIEMENS PLC (S7-1500). I use the PLC OPCUA Server (not the siemens driver). The PLC is declared as an OPC Server connection (and not as a device)
The problematic folder contains about 690 items. My guess is that it is too much for the OPC Browser.
Items can be addressed by typing manually the itemPath.
Other folders can be browsed by the OPC Browser without any UaServiceFaultException.
The problematic folder is browsed without any error with an external UA Client (UAExpert).
My questions are :
Does this exception come from the number of items in the folder ?
If yes, how can this limit be raised ?
Any help or clue highly appreciated.
Regards.
[quote]com.inductiveautomation.ignition.client.gateway_interface.GatewayException: UaServiceFaultException: status=Bad_TooManyOperations, message=The request could not be processed because it specified too many operations.
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:327)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:297)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invokeWithTimeout(GatewayInterface.java:896)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.browseOPC(GatewayInterface.java:900)
at com.inductiveautomation.ignition.designer.sqltags.opcbrowser.OPCFolderNode.loadChildren(OPCFolderNode.java:52)
at com.inductiveautomation.ignition.client.util.gui.tree.AbstractAsynchronousTreeNode$Loader.run(AbstractAsynchronousTreeNode.java:75)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.util.concurrent.ExecutionException
com.inductiveautomation.ignition.common.GenericTransferrableException: UaServiceFaultException: status=Bad_TooManyOperations, message=The request could not be processed because it specified too many operations.
at java.util.concurrent.CompletableFuture.reportGet(Unknown Source)
at java.util.concurrent.CompletableFuture.get(Unknown Source)
at com.inductiveautomation.xopc2.client.OpcUaConnection.browse(OpcUaConnection.java:495)
at com.inductiveautomation.ignition.gateway.opc.OPCManagerImpl$ServerWrapper.browse(OPCManagerImpl.java:754)
at com.inductiveautomation.ignition.gateway.opc.OPCManagerImpl.browse(OPCManagerImpl.java:468)
at com.inductiveautomation.ignition.gateway.sqltags.tagproviders.internal.InternalSQLTagsProvider.browseOPC(InternalSQLTagsProvider.java:79)
at com.inductiveautomation.ignition.gateway.sqltags.providers.RedundantProviderWrapper.browseOPC(RedundantProviderWrapper.java:174)
at com.inductiveautomation.ignition.gateway.sqltags.SQLTagsManagerImpl.browseOPC(SQLTagsManagerImpl.java:925)
at com.inductiveautomation.ignition.gateway.project.ProjectSettingsCache$ProjectDefaultTagManagerFacade.browseOPC(ProjectSettingsCache.java:484)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.SQLTags.browseOPC(SQLTags.java:814)
at sun.reflect.GeneratedMethodAccessor17.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.inductiveautomation.ignition.gateway.clientcomm.progress.MethodInvokeRunnable.run(MethodInvokeRunnable.java:27)
at com.inductiveautomation.ignition.gateway.clientcomm.progress.GatewayProgressManagerImpl$GatewayProgressTask.run(GatewayProgressManagerImpl.java:233)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:537)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
… 3 more
Caused by: org.eclipse.milo.opcua.stack.core.UaServiceFaultException
at org.eclipse.milo.opcua.stack.client.UaTcpStackClient.receiveResponse(UaTcpStackClient.java:283)
at org.eclipse.milo.opcua.stack.client.UaTcpStackClient.lambda$sendRequest$3(UaTcpStackClient.java:145)
at java.util.concurrent.CompletableFuture.uniWhenComplete(Unknown Source)
at java.util.concurrent.CompletableFuture$UniWhenComplete.tryFire(Unknown Source)
at java.util.concurrent.CompletableFuture.postComplete(Unknown Source)
at java.util.concurrent.CompletableFuture.complete(Unknown Source)
at org.eclipse.milo.opcua.stack.client.handlers.UaTcpClientMessageHandler.lambda$null$19(UaTcpClientMessageHandler.java:528)
… 3 more
Ignition v7.8.4 (b2016082217)
Java: Oracle Corporation 1.8.0_111[/quote]
