OPC-UA Communication Tag Conversion
Hi Team I am trying to add OPC-UA tags which got as Document/JSON tags after configuration and I want to extract required data currently i found below 2 methods.
  1. create Derived or Expression tags and use script to extract required data.
  2. Write script directly on received tags and extract required value and assign to seperate tags.
  3. Is there any alternate way apart from above 2 methods which can extract the required value directly during receiving process?
Method 1 is most efficient, particularly if you use just a jsonGet() expression, no script.
