Hello @Kevin.Herron , Can you please help with this issue.
We are trying to establish the OPC-UA connection between Ignition gateway and Siemens PCS7 v9.0.
Got the error Bad_SecurityChecksFailed .
Attached the error log.error.txt (2.2 KB)
Can anyone help me with the error message?
Ignition OPC configuration:
Security policy: Basic256sha256
Security mode: Sign&Encrypt
Ignition has accepted the certificate from siemens wincc.
Siemens side configuration
Since there is no option to accept the ignition client certificate, we have copied to the specific location in the siemens server.
Server endpoint selection:
Certificate trusted
Connection error
It looks like you’ve done all the things you’re supposed to do and WinCC is still sending back the Bad_SecurityChecksFailed error. You’ll probably have to contact Siemens support if you can’t figure out how to get more information about why.
Thanks for the reply
Have you checked the error log attached?
error.txt (2.2 KB)
Yes, the error is how I know it’s coming from the server and not being generated client side.
Thanks, @Kevin.Herron ,
Suspected the same. Raised a request with siemens.
zxcslo
February 1, 2021, 7:41pm
6
Have you tried completely compile the PCS7 project and downloading it again?
Hello all,
We are able to rectify the issue. We found there are 2 root causes
Wincc connectivity pack license not available
OPC-UA client (ignition) should authenticate against the windows credentials of WinCC station.
Thanks for your support!
Regards,
Saravanan.
