Update: Disabling ‘Certificate Validation Enabled’ fixed the problem for now. I guess the validation changed somewhere between 8.0.10 and 8.1.
I just upgraded Ignition to 8.1.0 and the connection to a OPC-UA server (TANI) stopped working.
The status page shows a certificate error. Thats strange, because security is set to None.
UaException: status=Bad_CertificateUriInvalid, message=The URI specified in the ApplicationDescription does not match the URI in the Certificate.
at org.eclipse.milo.opcua.stack.core.util.validation.CertificateValidationUtil.checkApplicationUri(CertificateValidationUtil.java:685)
at org.eclipse.milo.opcua.stack.client.security.DefaultClientCertificateValidator.validateCertificateChain(DefaultClientCertificateValidator.java:100)
at org.eclipse.milo.opcua.sdk.client.api.identity.UsernameProvider.getIdentityToken(UsernameProvider.java:162)
at org.eclipse.milo.opcua.sdk.client.session.SessionFsmFactory.activateSession(SessionFsmFactory.java:881)
at org.eclipse.milo.opcua.sdk.client.session.SessionFsmFactory.lambda$configureActivatingState$17(SessionFsmFactory.java:345)
at com.digitalpetri.strictmachine.dsl.ActionBuilder$PredicatedTransitionAction.execute(ActionBuilder.java:76)
at com.digitalpetri.strictmachine.StrictMachine$PollAndEvaluate.lambda$run$0(StrictMachine.java:242)
at java.base/java.util.ArrayList.forEach(Unknown Source)
at com.digitalpetri.strictmachine.StrictMachine$PollAndEvaluate.run(StrictMachine.java:227)
8.1.0 (b2020110211)
Azul Systems, Inc. 11.0.7
This message appears in the gateway log every few seconds
INFO | jvm 1 | 2020/11/29 16:53:30 | W [o.e.m.o.s.c.s.OpcUaBinaryStreamEncoder] [15:53:30]: Not a built-in type: class java.math.BigInteger
Any ideas?
