OPC UA server Faulted error,
After Installing ignition again, its still not solved.
I have also, removed cache and cookies, changed port and IP in server setting, bind address, removed temp file from C drive. i am facing Same problem.
my Ignition version is ignition-8.1.16 x64, windows 10.
database in workbench to ignition and program simulator is working properly except OPC server.
because of server error, i am not able to add tags for alarm output data in SQL and not able to see prespective and vision view to see visual representation of output data.
it will be very helpful if anyone provide answer. otherwise i will not be able to use ignition in this system afterward.
