I have connected the Ignition Gateway & Redlion DAQ device with OPC UA server configured in it. The connection in Ignition is very often getting Faulted with following error. By the same time I can see the Redlion device is working and even I could able to ping the device. Need a solution to resolve this problem.
session inactive: id=NodeId{ns=0, id=10002} name=ignition[Ignition-hostname]_REDLION_OPC_UA_1572350442525
java.lang.Exception: session inactive: id=NodeId{ns=0, id=10002} name=ignition[Ignition-hostname]_REDLION_OPC_UA_1572350442525
	at com.inductiveautomation.ignition.gateway.opcua.client.connection.OpcUaConnection$MiloSessionActivityListener.onSessionInactive(OpcUaConnection.kt:243)
	at org.eclipse.milo.opcua.sdk.client.session.SessionFsmFactory.lambda$null$31(SessionFsmFactory.java:557)
	at java.util.concurrent.CopyOnWriteArrayList.forEach(Unknown Source)
	at org.eclipse.milo.opcua.sdk.client.session.SessionFsmFactory.lambda$configureActiveState$32(SessionFsmFactory.java:557)
	at com.digitalpetri.strictmachine.dsl.ActionBuilder$PredicatedTransitionAction.execute(ActionBuilder.java:76)
	at com.digitalpetri.strictmachine.StrictMachine$PollAndEvaluate.lambda$run$0(StrictMachine.java:207)
	at java.util.ArrayList.forEach(Unknown Source)
	at com.digitalpetri.strictmachine.StrictMachine$PollAndEvaluate.run(StrictMachine.java:198)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
	at java.lang.Thread.run(Unknown Source)
7.9.12 (b2019070213)
Oracle Corporation 1.8.0_202
