We are evaluating interoperability with our UA Server based on the UA .NET Samples available here:
http://opcfoundation.github.io/UA-.NET/
The connection works, but the browse fails with a dialog box showing the error below.
Thank you very much for the attention!
Best regards
Mello
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: java.lang.IllegalArgumentException
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.newGatewayException(GatewayInterface.java:327)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.sendMessage(GatewayInterface.java:297)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.invokeWithTimeout(GatewayInterface.java:896)
at com.inductiveautomation.ignition.client.gateway_interface.GatewayInterface.browseOPC(GatewayInterface.java:900)
at com.inductiveautomation.ignition.designer.sqltags.opcbrowser.OPCFolderNode.loadChildren(OPCFolderNode.java:52)
at com.inductiveautomation.ignition.client.util.gui.tree.AbstractAsynchronousTreeNode$Loader.run(AbstractAsynchronousTreeNode.java:75)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
Caused by: java.util.concurrent.ExecutionException
com.inductiveautomation.ignition.common.GenericTransferrableException: java.lang.IllegalArgumentException
at java.util.concurrent.CompletableFuture.reportGet(Unknown Source)
at java.util.concurrent.CompletableFuture.get(Unknown Source)
at com.inductiveautomation.xopc2.client.OpcUaConnection.browse(OpcUaConnection.java:442)
at com.inductiveautomation.ignition.gateway.opc.OPCManagerImpl$ServerWrapper.browse(OPCManagerImpl.java:703)
at com.inductiveautomation.ignition.gateway.opc.OPCManagerImpl.browse(OPCManagerImpl.java:426)
at com.inductiveautomation.ignition.gateway.sqltags.tagproviders.internal.InternalSQLTagsProvider.browseOPC(InternalSQLTagsProvider.java:78)
at com.inductiveautomation.ignition.gateway.sqltags.providers.RedundantProviderWrapper.browseOPC(RedundantProviderWrapper.java:174)
at com.inductiveautomation.ignition.gateway.sqltags.SQLTagsManagerImpl.browseOPC(SQLTagsManagerImpl.java:921)
at com.inductiveautomation.ignition.gateway.project.ProjectSettingsCache$ProjectDefaultTagManagerFacade.browseOPC(ProjectSettingsCache.java:482)
at com.inductiveautomation.ignition.gateway.servlets.gateway.functions.SQLTags.browseOPC(SQLTags.java:826)
at sun.reflect.GeneratedMethodAccessor62.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at com.inductiveautomation.ignition.gateway.clientcomm.progress.MethodInvokeRunnable.run(MethodInvokeRunnable.java:27)
at com.inductiveautomation.ignition.gateway.clientcomm.progress.GatewayProgressManagerImpl$GatewayProgressTask.run(GatewayProgressManagerImpl.java:233)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:537)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
… 3 more
Caused by: java.lang.IllegalArgumentException
at com.google.common.base.Preconditions.checkArgument(Preconditions.java:108)
at com.google.common.collect.Lists.partition(Lists.java:653)
at com.inductiveautomation.xopc2.client.OpcUaConnection.lambda$null$39(OpcUaConnection.java:488)
at java.util.concurrent.CompletableFuture.uniCompose(Unknown Source)
at java.util.concurrent.CompletableFuture$UniCompose.tryFire(Unknown Source)
at java.util.concurrent.CompletableFuture.postComplete(Unknown Source)
at java.util.concurrent.CompletableFuture.complete(Unknown Source)
at com.digitalpetri.opcua.stack.client.UaTcpStackClient.receiveResponse(UaTcpStackClient.java:280)
at com.digitalpetri.opcua.stack.client.UaTcpStackClient.lambda$sendRequest$9(UaTcpStackClient.java:151)
at java.util.concurrent.CompletableFuture.uniWhenComplete(Unknown Source)
at java.util.concurrent.CompletableFuture$UniWhenComplete.tryFire(Unknown Source)
at com.digitalpetri.opcua.stack.client.handlers.UaTcpClientSymmetricHandler.lambda$null$26(UaTcpClientSymmetricHandler.java:215)
… 3 more
Ignition v7.8.1 (b2016012216)
Java: Oracle Corporation 1.8.0_74
