I am getting the below error on my S7-1500 PLC OPC UA Server. Another thing of note is that the vision application and tag updates seem to be more sluggish than I'm familiar with.
java.lang.Exception: session inactive: id=NodeId{ns=1, id=1326793202} name=ignition[Ignition-5044]_SIMATIC.S7-1500.OPC-UA.Application:5044PLCA_1747849305404
at com.inductiveautomation.ignition.gateway.opcua.client.connection.OpcUaConnection$MiloSessionActivityListener.onSessionInactive(OpcUaConnection.kt:499)
at org.eclipse.milo.opcua.sdk.client.session.SessionFsmFactory.lambda$null$39(SessionFsmFactory.java:611)
at java.base/java.util.concurrent.CopyOnWriteArrayList.forEach(Unknown Source)
at org.eclipse.milo.opcua.sdk.client.session.SessionFsmFactory.lambda$configureActiveState$40(SessionFsmFactory.java:611)
at com.digitalpetri.strictmachine.dsl.ActionBuilder$PredicatedTransitionAction.execute(ActionBuilder.java:119)
at com.digitalpetri.strictmachine.StrictMachine$PollAndEvaluate.lambda$run$0(StrictMachine.java:242)
at java.base/java.util.ArrayList.forEach(Unknown Source)
at com.digitalpetri.strictmachine.StrictMachine$PollAndEvaluate.run(StrictMachine.java:227)
8.1.39 (b2024040909)
Azul Systems, Inc. 17.0.10
