Hello,
I am in the process of creating an OPC UA module and have run into issues adding names and descriptions to additional fields on the device settings.
I even tried to do this update directly with the simple Example opc-ua-device project and am seeing the same issue.
First I added additional field TEST_FIELD under the standard TAG_COUNT field and added to example category.
And then, I added name and description properties in ExampleDeviceSettings.properties
I re-compile the module and re-install and I get the following on the add device screen:
I even unzipped the compiled modl file to ensure that updated properties are in there and they are.
Can anyone help me to understand what I am doing wrong here?
Appreciate any responses. Thanks!
