OPC-UA Error - "Bad_EncodingLimitsExceeded
this error appeard in the quick-client on Ignition 8.1 - Edge.
Anybody aware of this OPC-UA Error: "Bad_EncodingLimitsExceeded: The message encoding/decoding limits imposed by the stack have been exceeded."
Anybody aware of this issue and how to fix it? The server is self-developed. Reading the node is no issue with Prosys Client or UA-Expert
Usually happens when one side or the other tries to encode a message that is too large.
Sometimes happens when a message is encoded incorrectly and the length field ends up containing a bogus value.
Will probably need Wireshark capture to see.
Thank you for your quick reply,
  • I will ask to check this and hopefully get a feedback end of next week, with a wireshark capture.
  • We will also test it with 8.3.
  • Just wondering why it works with other clients.
Couldn't answer this without a capture to see what limits each client negotiates, what service or operation fails or doesn't fail, etc...
I sent you two pcaps / wireshark captures with the error when using Igntion and without when using another client.
Would be great to understand where we have the issue.
