Hi all!
I have 2 PC with redundant ignition OPC UA servers(the master is 10.0.8.65 and the backup is 10.0.8.71). I have a 3rd PC with ignition getting data from these redundant ignition servers via opcua. When I test stopping the master gateway, the redundancy works and all my data are still alive for the client.
However on my 3rd PC, the opcua server connection becomes faulted. I have configured failover and I am expecting that when the primary opcua server becomes faulted, it will try to connect to the failover endpoint server. But when I check the logs, it keeps on trying to connect to the primary only. It does not switch on connecting to the failover.
UaException: status=Bad_ConnectionRejected, message=java.net.ConnectException: Connection refused: no further information: /10.0.8.65:4096
at org.eclipse.milo.opcua.stack.client.UaTcpStackClient.lambda$bootstrap$15(UaTcpStackClient.java:510)
at io.netty.util.concurrent.DefaultPromise.notifyListener0(DefaultPromise.java:683)
at io.netty.util.concurrent.DefaultPromise.notifyListeners0(DefaultPromise.java:604)
at io.netty.util.concurrent.DefaultPromise.notifyListeners(DefaultPromise.java:564)
at io.netty.util.concurrent.DefaultPromise.tryFailure(DefaultPromise.java:425)
at io.netty.channel.nio.AbstractNioChannel$AbstractNioUnsafe.fulfillConnectPromise(AbstractNioChannel.java:276)
at io.netty.channel.nio.AbstractNioChannel$AbstractNioUnsafe.finishConnect(AbstractNioChannel.java:292)
at io.netty.channel.nio.NioEventLoop.processSelectedKey(NioEventLoop.java:545)
at io.netty.channel.nio.NioEventLoop.processSelectedKeysOptimized(NioEventLoop.java:485)
at io.netty.channel.nio.NioEventLoop.processSelectedKeys(NioEventLoop.java:399)
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:371)
at io.netty.util.concurrent.SingleThreadEventExecutor$2.run(SingleThreadEventExecutor.java:112)
at java.lang.Thread.run(Unknown Source)
Caused by: java.net.ConnectException: Connection refused: no further information: /10.0.8.65:4096
at sun.nio.ch.SocketChannelImpl.checkConnect(Native Method)
at sun.nio.ch.SocketChannelImpl.finishConnect(Unknown Source)
at io.netty.channel.socket.nio.NioSocketChannel.doFinishConnect(NioSocketChannel.java:224)
at io.netty.channel.nio.AbstractNioChannel$AbstractNioUnsafe.finishConnect(AbstractNioChannel.java:289)
… 6 more
7.9.9 (b2018081621)
Oracle Corporation 1.8.0_181
I also created a separate opcua server for the master and the backup on my 3rd pc just to ensure that I can connect to them properly and yes, I have good connection to them.
I have seen a very similar scenario in this forum OPC Server Connection Redundancy Settings, however, his solution did not work for me.
Maybe I am missing something. But I already tried different combinations of enabling the backup and the failover but to no luck. I hope you can shed some ideas on how I can make this work.
I am using Igition 7.9.9
Thank you so much in advance.
