I'm attempting to use a PI Connector to Historize data using Ignition's OPC UA Server as the interface. However, when I restarted the ignition gateway the OPC UA Module now faults with an error that the collection is empty? How do I address this?
java.lang.IllegalArgumentException: Collection is empty
at java.base/java.util.EnumSet.copyOf(Unknown Source)
at com.inductiveautomation.ignition.gateway.opcua.OpcUaModule$setup$config$1.(OpcUaModule.kt:245)
at com.inductiveautomation.ignition.gateway.opcua.OpcUaModule.setup(OpcUaModule.kt:226)
at com.inductiveautomation.ignition.gateway.opcua.OpcUaModuleHook.setup(OpcUaModuleHook.kt)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl$LoadedModule.setup(ModuleManagerImpl.java:2407)
at com.inductiveautomation.ignition.gateway.modules.ModuleManagerImpl.setup(ModuleManagerImpl.java:392)
at com.inductiveautomation.ignition.gateway.IgnitionGateway.startupInternal(IgnitionGateway.java:1161)
at com.inductiveautomation.ignition.gateway.redundancy.RedundancyManagerImpl.startup(RedundancyManagerImpl.java:288)
at com.inductiveautomation.ignition.gateway.IgnitionGateway.initRedundancy(IgnitionGateway.java:732)
at com.inductiveautomation.ignition.gateway.IgnitionGateway.lambda$initInternal$0(IgnitionGateway.java:666)
at com.inductiveautomation.ignition.common.execution.impl.BasicExecutionEngine$ThrowableCatchingRunnable.run(BasicExecutionEngine.java:539)
at java.base/java.lang.Thread.run(Unknown Source)8.1.9 (b2021080617)
Azul Systems, Inc. 11.0.11
Blockquote
