OPC UA server Client with raspberry pi (4DIAC IDE)
I have problems, when i try running this programs, at QX output “merah_0” has “TRUE” value in client, and i try to connect with raspi, but at gpio raspi can’t switch on the lamp.
I use opc ua client and server to communicate all of them and 4diac ide to run the programs.
how can i solve this problems?
Did you check this?
is it okay when i use 4DIAC IDE? is it same with other software to run program?
