I am trying to setup an OPC connection from gw25 gateway to gw28 gateway. I configured gw28’s OPC UA server settings correctly and am able to select an endpoint from gw25 gateway. After hitting next on the screen of selecting the endpoint, I receive “Internal Error. Return to home page”. Here’s the errors from the log. Attached are snips of the screen before the error and the error. I am not sure what to do to correct fix this.
ERROR 1:
MarkupFactory 14Jul2021 06:22:05 Error while reading the markup jar:file:/usr/local/bin/ignition/data/jar-cache/com.inductiveautomation.opcua/__293852800__opc-ua-gateway-9.1.1.jar!/com/inductiveautomation/ignition/gateway/opcua/client/connection/web/discovery/wizardsteps/ManageCertificateStep.html
org.apache.wicket.WicketRuntimeException: Expected to find in base markup: jar:file:/usr/local/bin/ignition/data/jar-cache/com.inductiveautomation.opcua/__293852800__opc-ua-gateway-9.1.1.jar!/com/inductiveautomation/ignition/gateway/opcua/client/connection/web/discovery/wizardsteps/AbstractDiscoveryWizardStep.html
at org.apache.wicket.markup.MergedMarkup.merge(MergedMarkup.java:246)
at org.apache.wicket.markup.MergedMarkup.(MergedMarkup.java:85)
at org.apache.wicket.markup.loader.InheritedMarkupMarkupLoader.loadMarkup(InheritedMarkupMarkupLoader.java:82)
at org.apache.wicket.markup.loader.DefaultMarkupLoader.loadMarkup(DefaultMarkupLoader.java:52)
at org.apache.wicket.markup.MarkupFactory.loadMarkup(MarkupFactory.java:412)
at org.apache.wicket.markup.MarkupCache.loadMarkup(MarkupCache.java:448)
at org.apache.wicket.markup.MarkupCache.loadMarkupAndWatchForChanges(MarkupCache.java:541)
at org.apache.wicket.markup.MarkupCache.getMarkup(MarkupCache.java:305)
at org.apache.wicket.markup.MarkupFactory.getMarkup(MarkupFactory.java:236)
at org.apache.wicket.markup.MarkupFactory.getMarkup(MarkupFactory.java:194)
at org.apache.wicket.MarkupContainer.getAssociatedMarkup(MarkupContainer.java:401)
at org.apache.wicket.MarkupContainer.getAssociatedMarkupStream(MarkupContainer.java:368)
at org.apache.wicket.markup.html.panel.AssociatedMarkupSourcingStrategy.renderHeadFromAssociatedMarkupFile(AssociatedMarkupSourcingStrategy.java:244)
at org.apache.wicket.markup.html.panel.AssociatedMarkupSourcingStrategy.renderHead(AssociatedMarkupSourcingStrategy.java:220)
at org.apache.wicket.Component.renderHead(Component.java:2676)
at org.apache.wicket.markup.renderStrategy.ChildFirstHeaderRenderStrategy$1.component(ChildFirstHeaderRenderStrategy.java:85)
at org.apache.wicket.markup.renderStrategy.DeepChildFirstVisitor.visit(DeepChildFirstVisitor.java:96)
at org.apache.wicket.markup.renderStrategy.DeepChildFirstVisitor.visit(DeepChildFirstVisitor.java:87)
at org.apache.wicket.markup.renderStrategy.DeepChildFirstVisitor.visit(DeepChildFirstVisitor.java:51)
at org.apache.wicket.markup.renderStrategy.ChildFirstHeaderRenderStrategy.renderChildHeaders(ChildFirstHeaderRenderStrategy.java:78)
at org.apache.wicket.markup.renderStrategy.ChildFirstHeaderRenderStrategy.renderHeader(ChildFirstHeaderRenderStrategy.java:57)
at org.apache.wicket.markup.html.internal.HtmlHeaderContainer.onComponentTagBody(HtmlHeaderContainer.java:170)
at org.apache.wicket.markup.html.panel.DefaultMarkupSourcingStrategy.onComponentTagBody(DefaultMarkupSourcingStrategy.java:71)
at org.apache.wicket.Component.internalRenderComponent(Component.java:2535)
at org.apache.wicket.MarkupContainer.onRender(MarkupContainer.java:1491)
at org.apache.wicket.Component.internalRender(Component.java:2365)
at org.apache.wicket.Component.render(Component.java:2293)
at org.apache.wicket.MarkupContainer.renderNext(MarkupContainer.java:1388)
at org.apache.wicket.MarkupContainer.renderAll(MarkupContainer.java:1553)
at org.apache.wicket.Page.onRender(Page.java:884)
at org.apache.wicket.markup.html.WebPage.onRender(WebPage.java:142)
at org.apache.wicket.Page.renderPage(Page.java:1021)
at org.apache.wicket.request.handler.render.WebPageRenderer.renderPage(WebPageRenderer.java:116)
at org.apache.wicket.request.handler.render.WebPageRenderer.respond(WebPageRenderer.java:244)
at org.apache.wicket.core.request.handler.RenderPageRequestHandler.respond(RenderPageRequestHandler.java:165)
at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:814)
at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:97)
at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:253)
at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:210)
at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:281)
at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:188)
at org.apache.wicket.protocol.http.WicketFilter.doFilter(WicketFilter.java:245)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1596)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:545)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:590)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:127)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:235)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1607)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:233)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1297)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:188)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:485)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1577)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:186)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1212)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.rewrite.handler.RewriteHandler.handle(RewriteHandler.java:322)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:59)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:146)
at org.eclipse.jetty.server.Server.handle(Server.java:500)
at org.eclipse.jetty.server.HttpChannel.lambda$handle$1(HttpChannel.java:383)
at org.eclipse.jetty.server.HttpChannel.dispatch(HttpChannel.java:547)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:375)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:270)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:103)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:117)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:336)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:313)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:171)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:129)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:388)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:806)
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:938)
ERROR 2:
DefaultExceptionMapper 14Jul2021 06:22:05 Unexpected error occurred
org.apache.wicket.markup.MarkupNotFoundException: Markup of type 'html' for component 'com.inductiveautomation.ignition.gateway.opcua.client.connection.web.discovery.wizardsteps.ManageCertificateStep' not found. Enable debug messages for org.apache.wicket.util.resource to get a list of all filenames tried: [ManageCertificateStep [Component id = view]]
at org.apache.wicket.MarkupContainer.getAssociatedMarkup(MarkupContainer.java:426)
Caused by: org.apache.wicket.WicketRuntimeException: Expected to find in base markup: jar:file:/usr/local/bin/ignition/data/jar-cache/com.inductiveautomation.opcua/__293852800__opc-ua-gateway-9.1.1.jar!/com/inductiveautomation/ignition/gateway/opcua/client/connection/web/discovery/wizardsteps/AbstractDiscoveryWizardStep.html
... 73 common frames omitted
