OPC UA Server Faulted v8
I have upgraded to V8.0 in order to take the Ignition core exam and uploaded gwbk file provided by ignition
Ignition OPC UA Server is faulted and I am getting the following error
UaException: status=Bad_CertificateUriInvalid, message=The URI specified in the ApplicationDescription does not match the URI in the Certificate.
When I look at the opc-ua security settings the certs are showing invalid date
Hmm.
Try shutting down the gateway and then deleting these files:
  • $IGNITION/data/opcua/client/security/certificates.pfx
  • $IGNITION/data/opcua/server/security/certificates.pfx
Then start it up again.
what gwcmd would I use to stop… I see -r to restart alright
You can probably just delete those files and then restart it.
I don’t know if the gwcmd has start/stop service. If you’re on the command line you can already do that via the appropriate commands for your OS (net stop ignition etc…)
Deleting and restarting worked. Thanks again
