Hi all,
The last two days I have been experiencing an issue where the OPC UA server faults when I first start up my computer. I have been able to fix this by stopping the Ignition Gateway service, renaming the “opcua” folder found in C:\Program Files\Inductive Automation\Ignition\data to “opcua_old” and restarting the service. The error message from the logs is attached. Any ideas?
edit: looks like the image may be too small to read, here is the error:
INFO | jvm 1 | 2026/01/02 08:41:54 | E [o.e.m.o.s.c.t.u.UascClientAcknowledgeHandler] [08:41:54.459]: [remote=localhost/127.0.0.1:62541] Received error message: ErrorMessage{error=StatusCode{name=Bad_SecurityChecksFailed, value=0x80130000, quality=bad}, reason=status=Bad_SecurityChecksFailed, description=An error occurred verifying security.}
