OPC UA server is showing faulted
I am using Ignition 64bit linux on RED HART OS.
The OPC-UA server is showing Faulted.
The error is shown below:
"com.inductiveautomation.opcua.UAException.could notopen source channel to opc.tcp://localhost:8088/.
PLease share your answers to solve the problem immediately
Regards,
Mohammed Ghaziuddin
Software Engineer- PES INA
iGatePatni India
Ext:2109/2770 I cell: 9561435783 I ghaziuddin.mohammed@igatepatni.com
It appears that the connection is set for the wrong port. The OPC server listens by default on port 4096. You may need to also verify that the “endpoint” is set correctly. It is defined on the server under “Ignition OPC-UA Server > Settings > Server”.
Regards,
Hi Colby,
Please could you elobarate and share some document so that i can solve the issue.
Reagrds
Mohammed Ghaziuddin
