Hi!
We are connecting another software to Ignition trough opc-ua where Ignition is the OPC server. I am connecting to Ignition but cant see any tags and on the diagnostics side of the server there is no subscription for this connection. No error logs on the Ignition logs. On the other software I get the following error:
the secure channel has been closed on the target server.
UA Data Source certificate might not be trusted on the target server.
Please review OPC UA server configuration.
Remote side closed connection.
Opc.Ua.ServiceResultException: BadSecureChannelClosed
On wireshark I can see that Ignition sends [FIN,ACK] after hellos message from the other software.
Same behavior if i connect to opc.tcp://host:port/discovery and to opc.tcp://host:port with the same result
If we refresh the runtime of the other software then we succed to read tags, but this needs to be done manually everytime we do a connection
picture of wireshark
