I’m working on Migrating our Gateway to a new server.
After restoring the backup from the Original gateway, all looks good except I cant view/edit the OPC-UA Settings. I can view/edit the OPC-UA Device settings with no issues.
Thru the console on the Gateway the following error is logged whenever trying to veiw the OPC-UA settings:
8:17:29 AM Config Error creating panel class: class com.inductiveautomation.xopc.gateway.config.settings.SettingsPage
java.lang.reflect.InvocationTargetException
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at com.inductiveautomation.ignition.gateway.web.components.ConfigPanelNavLink.newConfigPanel(ConfigPanelNavLink.java:55)
at com.inductiveautomation.ignition.gateway.web.pages.Config.(Config.java:47)
at org.apache.wicket.session.DefaultPageFactory.newPage(DefaultPageFactory.java:170)
at org.apache.wicket.session.DefaultPageFactory.newPage(DefaultPageFactory.java:98)
at org.apache.wicket.DefaultMapperContext.newPageInstance(DefaultMapperContext.java:137)
at org.apache.wicket.core.request.handler.PageProvider.resolvePageInstance(PageProvider.java:278)
at org.apache.wicket.core.request.handler.PageProvider.getPageInstance(PageProvider.java:166)
at org.apache.wicket.request.handler.render.PageRenderer.getPage(PageRenderer.java:78)
at org.apache.wicket.request.handler.render.WebPageRenderer.renderPage(WebPageRenderer.java:94)
at org.apache.wicket.request.handler.render.WebPageRenderer.respond(WebPageRenderer.java:244)
at org.apache.wicket.core.request.handler.RenderPageRequestHandler.respond(RenderPageRequestHandler.java:165)
at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:814)
at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:253)
at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:210)
at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:281)
at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:188)
at org.apache.wicket.protocol.http.WicketFilter.doFilter(WicketFilter.java:245)
at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1650)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:583)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1125)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1059)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.HandlerList.handle(HandlerList.java:52)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)
at org.eclipse.jetty.server.Server.handle(Server.java:497)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:311)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:248)
at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:540)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:610)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:539)
at java.lang.Thread.run(Unknown Source)
Caused by: java.lang.RuntimeException: An error occurred while getting the model object for Component: [ReferenceEditor [Component id = 1, page = , path = 1.ReferenceEditor]]
at org.apache.wicket.Component.getDefaultModelObject(Component.java:1620)
at com.inductiveautomation.ignition.gateway.web.components.editors.AbstractEditor.getFormMeta(AbstractEditor.java:42)
at com.inductiveautomation.ignition.gateway.web.components.editors.AbstractEditor.createFieldRow(AbstractEditor.java:46)
at com.inductiveautomation.ignition.gateway.web.components.editors.AbstractEditor.(AbstractEditor.java:38)
at com.inductiveautomation.ignition.gateway.web.components.editors.ReferenceEditor.(ReferenceEditor.java:41)
at com.inductiveautomation.ignition.gateway.web.components.editors.ReferenceEditor.(ReferenceEditor.java:36)
at com.inductiveautomation.ignition.gateway.web.components.editors.ReferenceEditorSource.newEditorComponent(ReferenceEditorSource.java:42)
at com.inductiveautomation.ignition.gateway.localdb.persistence.FormMeta.newEditorComponent(FormMeta.java:168)
at com.inductiveautomation.ignition.gateway.web.components.RecordEditForm.newEditorComponent(RecordEditForm.java:297)
at com.inductiveautomation.ignition.gateway.web.components.RecordEditForm.addField(RecordEditForm.java:280)
at com.inductiveautomation.ignition.gateway.web.components.RecordEditForm.createCategoryTable(RecordEditForm.java:271)
at com.inductiveautomation.ignition.gateway.web.components.RecordEditForm.addStandardCategories(RecordEditForm.java:226)
at com.inductiveautomation.ignition.gateway.web.components.RecordEditForm.initComponents(RecordEditForm.java:174)
at com.inductiveautomation.ignition.gateway.web.components.RecordEditForm.init(RecordEditForm.java:116)
at com.inductiveautomation.ignition.gateway.web.components.RecordEditForm.(RecordEditForm.java:94)
at com.inductiveautomation.ignition.gateway.web.components.RecordEditForm.(RecordEditForm.java:78)
at com.inductiveautomation.xopc.gateway.config.settings.SettingsPage.(SettingsPage.java:22)
… 45 more
Caused by: java.lang.NullPointerException: No known record for table name: XOPCSettings
at com.inductiveautomation.ignition.gateway.localdb.LocalDBManagerImpl.findRecordMeta(LocalDBManagerImpl.java:289)
at com.inductiveautomation.ignition.gateway.web.models.FormMetaModel.load(FormMetaModel.java:34)
at com.inductiveautomation.ignition.gateway.web.models.FormMetaModel.load(FormMetaModel.java:21)
at org.apache.wicket.model.LoadableDetachableModel.getObject(LoadableDetachableModel.java:121)
at org.apache.wicket.Component.getDefaultModelObject(Component.java:1615)
… 61 more
System setup:
Version 7.7.4 (b2015033012) 32 bit
Java Version Oracle Corporation 1.8.0_45
Windows Server 2012R2
MySQL Server 5.7.9
Any Help Would be greatly Appreciated.
