Hi
I am running Ignition 7.5.6 on a Windows 2003 R2 SP1 virtual server.
I have a allen bradley controllogix device added to the Ignition OPC UA server.
I have 37 transactions with block data items totalling 17641 tags on this device. All transaction groups have the same execution frequency.
The problem is when i stop these groups or make a change and save those changes, firstly the device takes like 10 minutes to drop the items from subscription as i can see from the diagnostics and the wrapper log is filled with messages like
INFO | jvm 1 | 2013/04/02 08:10:51 | WARN [SamplingRateProvider ] [08:10:51,207]: Could not find any MonitoredItems for NodeId “[BH45LogHandling]Global.LTLogNos.LTLogNos[4465]”, using fallback of 1000ms.
INFO | jvm 1 | 2013/04/02 08:10:51 | WARN [SamplingRateProvider ] [08:10:51,207]: Could not find any MonitoredItems for NodeId “[BH45LogHandling]Global.LTLogNos.LTLogNos[4466]”, using fallback of 1000ms.
INFO | jvm 1 | 2013/04/02 08:10:51 | WARN [SamplingRateProvider ] [08:10:51,207]: Could not find any MonitoredItems for NodeId “[BH45LogHandling]Global.LTLogNos.LTLogNos[4467]”, using fallback of 1000ms.
INFO | jvm 1 | 2013/04/02 08:10:51 | WARN [SamplingRateProvider ] [08:10:51,207]: Could not find any MonitoredItems for NodeId “[BH45LogHandling]Global.LTLogNos.LTLogNos[4468]”, using fallback of 1000ms.
INFO | jvm 1 | 2013/04/02 08:10:51 | WARN [SamplingRateProvider ] [08:10:51,207]: Could not find any MonitoredItems for NodeId “[BH45LogHandling]Global.LTLogNos.LTLogNos[4469]”, using fallback of 1000ms.
INFO | jvm 1 | 2013/04/02 08:10:51 | WARN [SamplingRateProvider ] [08:10:51,207]: Could not find any MonitoredItems for NodeId “[BH45LogHandling]Global.LTLogNos.LTLogNos[4470]”, using fallback of 1000ms.
INFO | jvm 1 | 2013/04/02 08:10:51 | WARN [SamplingRateProvider ] [08:10:51,347]: Could not find any MonitoredItems for NodeId “[BH45LogHandling]Global.LTLogNos.LTLogNos[4471]”, using fallback of 1000ms.
INFO | jvm 1 | 2013/04/02 08:10:51 | WARN [SamplingRateProvider ] [08:10:51,347]: Could not find any MonitoredItems for NodeId “[BH45LogHandling]Global.LTLogNos.LTLogNos[4472]”, using fallback of 1000ms.
INFO | jvm 1 | 2013/04/02 08:10:51 | WARN [SamplingRateProvider ] [08:10:51,347]: Could not find any MonitoredItems for NodeId “[BH45LogHandling]Global.LTLogNos.LTLogNos[4473]”, using fallback of 1000ms.
INFO | jvm 1 | 2013/04/02 08:10:51 | WARN [SamplingRateProvider ] [08:10:51,347]: Could not find any MonitoredItems for NodeId “[BH45LogHandling]Global.LTLogNos.LTLogNos[4474]”, using fallback of 1000ms.
INFO | jvm 1 | 2013/04/02 08:10:51 | WARN [SamplingRateProvider ] [08:10:51,347]: Could not find any MonitoredItems for NodeId “[BH45LogHandling]Global.LTLogNos.LTLogNos[4475]”, using fallback of 1000ms.
INFO | jvm 1 | 2013/04/02 08:10:52 | WARN [SamplingRateProvider ] [08:10:51,347]: Could not find any MonitoredItems for NodeId “[BH45LogHandling]Global.LTLogNos.LTLogNos[4476]”, using fallback of 1000ms.
INFO | jvm 1 | 2013/04/02 08:10:52 | WARN [SamplingRateProvider ] [08:10:51,488]: Could not find any MonitoredItems for NodeId “[BH45LogHandling]Global.LTLogNos.LTLogNos[4477]”, using fallback of 1000ms.
Once the messages end, the items are slowly dropped from subscription. This process is taking like a good 10 minutes, means 10 minutes of data loss.
