Hi:
After the OPCUA device is connected, the gateway shows as connected, but in reality, the value inside shows bad. Setting the driver to disable and then switching to enable cannot solve this problem. How should I solve this problem? Thank you
Hi:
what device driver are you using?
Omron NJ Driver
Have you look at its diagnostics page?
Have you loaded that specific tag into the driver configuration? (You must export tags from Sysmac Studio and load them into the driver. Only those tags will work.)
If you need a driver that auto-browses Omron NJ/NX devices, consider this alternate driver:
/shameless plug
