We are interfacing with Weidmuller I/O’s and Mitsubishi GOC43 on Modbus TCP. In both cases, when we attempt to write tags, the first tag gets through and subsequently we get write errors. Wonder if is a known problem and if yes what are the recommended corrective actions. Matter most urgent.
Can you provide more information? What version of Ignition are you using? How are you initiating the write? Do you have logs? Wireshark capture?
error_file.zip (965.9 KB) please find the attached Wireshark capture and log. We are using Ignition 8.0.16,and initiating the write via property change script.
