After converting the last of my SQL Tags I get the following continuous error. Every time the gateway is restarted, it throws up a different address. I am running version 4408
java.lang.IllegalArgumentException: value already present: [L12Mixer]N54:318
com.google.common.base.Preconditions.checkArgument(Preconditions.java:116)
com.google.common.collect.StandardBiMap.putInBothMaps(StandardBiMap.java:106)
com.google.common.collect.StandardBiMap.put(StandardBiMap.java:91)
com.google.common.collect.HashBiMap.put(HashBiMap.java:82)
com.inductiveautomation.xopc.client.srremoteserver.DefaultSRRemoteServer$SRSubscriptionDetails.putNodeId(DefaultSRRemoteServer.java:891)
com.inductiveautomation.xopc.client.srremoteserver.DefaultSRRemoteServer.subscribe(DefaultSRRemoteServer.java:672)
com.inductiveautomation.xopc.client.sropcserver.SROPCServerImpl.subscribe(SROPCServerImpl.java:977)
com.inductiveautomation.xopc.client.sropcserver.SROPCServerImpl.access$600(SROPCServerImpl.java:90)
com.inductiveautomation.xopc.client.sropcserver.SROPCServerImpl$FailedNodeResubscriber.run(SROPCServerImpl.java:1273)
com.inductiveautomation.ignition.gateway.execution.BasicExecutionEngine$TrackedTask.run(BasicExecutionEngine.java:403)
java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
java.util.concurrent.FutureTask$Sync.innerRunAndReset(Unknown Source)
java.util.concurrent.FutureTask.runAndReset(Unknown Source)
java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$101(Unknown Source)
java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.runPeriodic(Unknown Source)
java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
java.lang.Thread.run(Unknown Source)
